Question about xheli Toys
Dh830 helicopter how do you charge the helicopter
How do I charge my Tech Toyz Aeroblade tactical wireless indoor helicopter? No manual.
The helicopter charges off of the batteries in the controller as follows:
  • Connect the helicopter to the controller as shown in the picture. Make sure there are good batteries in the controller.
  • Turn the helicopter off.
  • Turn the controller on. The red "power" light and the green "charge" light on the controller should come on.
  • When the green light turns off, the helicopter is done charging.
Apr 14, 2015 | Toys
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
I can't seem to charge my S107 helicopter. I plug the USB charging cable into my computer, and then the helicopter itself, but have no indication that it is charging. Should I see a light on the...
You should see the orange LED glow when you first plug the cable in. Once you plug the heli in, the LED should go out. Once the heli is charged, the LED will come back on.
Jan 01, 2011 | SYMA Toys industrial New Syma S107 Radio...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
Purchased Helicopter MINI AIR WOLF Model UJ417. from RiverCenter Mall vendor in San Antonio, Texas 3 days ago, while on vacation...live in kansas.Hope i didn't get scammed. Vendor never said it would only...
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Sep 01, 2010 | Toys
Toys Logo
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
