2002 Jeep Liberty Logo
Posted on May 19, 2009
Need timing marks for jeep liberty
I am trying to fine the timing chain marks and setting for 2002 jeep liberty with a 3.7 engine
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3239
Points
17
Necesito marcar jeep liberty 2002 3.7
  • Nel Tua Sep 19, 2013
    Solution is totally out of the question..Is this website current or not???I had asked a question on Setup for a timing mark set up for a 1991 Jeep Wrangler?? Solution is way off from question..please up date your website..otherwise might aswell delete it..
2002 jeep liberty motor-2.4 chain driven component below crankshaft need to find if position matters and how to time
no photos. so help will limited .
all cam timing matters.
"not sure what does", the cam, crank, sprocket or pin?
The 2.4L inline 4 engine, is a throw back old Dodge Neons
DOHC engine ,a twin cam head.
2002 is first year, Liberty in USA>
is this the 2.4L turbo engine, EDZ engine.??
KJ jeep it is.
be nice to say what job your working? HOw'd you get here?
if you buy the service manual from jeep
chapter 9s, covers this 2.4 total engine, in one chapter.
but this engine cams are Belt drive. NOT CHAIN.
first post that it really is, this engine? or the VIN, or photos.
so you must be confused on that is there.
the other engine, the 3.7L is a V6 engine vastly different than the 4 banger.
it has chains.
covered in chapter 9- page 71 +
this v6 has a counterbalancer too.
i recommend reading the FSM book on this engine , after counting cylinder, 4 or 6? and reading chapters 9 or 9s.
see KJ 2002 here
RTM read the manual
seen here
http://colorado4wheel.com/manuals/Jeep/KJ/
Diagram timing of v6 engine of liberty 2001 model
that v6 engine has no timing adjustment. it has a timing chain. so if there is a stretch on chain, it must be replaced according to factory service manual. only thing you need to watch is to mark the position of gears before you remove chain. also timing of ignition is maintained by engine controller. if you need a custom setup you need chip tuning for that.
1helpful
1helpful
2answers
Does it have a timing belt or chain and when does it need to be changed
Hello there and than you for choosing fixya
Your vehical has a timing chain see the pict and price below around any where around the 100 to 120,000 mile mark the chain should be changed
Timing Kit/component/Timing Chain
Price:
$33.99
2helpful
How to set the timing marks on the cams on a02 jeep liberty 3.7 engine
wow not going to say the job> ?
heads off or what?
2002 Liberty.? KJ car. (USA)
ever seen a real FSM? "factory service manual"
and all those steps? to do work on that engine.
here it is , read it, then ask questions?
6helpful
I am trying to find timing chain marks for 2005 jeep liberty
o lord very difficult engine to time man. word of advise don't remove the primary oil pump chain. there are no marks. line the bigger oil pump sprocket DOT to 12 oclock if you have the chain lock tool this makes life a lot easier. Both of the cam sprocket have a V6 mark on it they should be at 12 oclock. If everything line up like that u are golden. Hope this helps. If you need step by step instrutions I will help. Rate me please
2helpful
2002 jeep liberty timming marks
you cant without proper computer tools
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
