Question about Brother GX-6750 Typewriter
How to release cap button
After putting cap button on, , how to get it back off?
  • 24 Answers
Press shift. If that doesn't work, make sure that no foreign object (like a paper clip) is under any of the keys.
Posted on Jan 02, 2014
Gas cover will not release on my 2002 Volvo s60
Check for faulty switch---fuse and power at solenoid release at cap door.
Mar 23, 2013 | 2002 Volvo S60
How 2 put back on a distributor cap n where is it located
Depending on what you have you might not even have one but if you do follow spark plug wires to where they all meet up (Distributor Cap) is where they all come together. On the sides of the Cap there should be springs that can be released, if you don't know your firing order then mark with masking tape each wire to where on the cap it goes so you can match it up on the new. Usually you will replace the Rotor as well its under the Distributor Cap in the middle usually you just pull it up and off and the reverse to put new one on. Once you've done this put the Distributor Cap back on and lock springs down. Hope this helps but difficult to answer not knowing what your driving, Engine etc.
Jan 22, 2013 | 2001 Chevrolet Malibu
2001 montero limited randomly wont start after setting a while starts fine
Check your gas cap and fuel pump. If you can start it after loosening the cap and putting it back on, your fuel pump is starting to die. It can't pull the gas out of the tank. When you release the cap, you let air in and release the vacuum in the tank.
Dec 13, 2012 | 2001 Mitsubishi Montero
How do I change the rear turn signal bulb on a 2004 Sebring convertible?
Peel back the trunk lining to reveal three wing nuts. Remove wing nuts to pull lens cap away from car. To remove bulb socket push on the rectangular button (the release) while pushing on the end of the socket to unlock and spin counter clockwise to release. pull out old bulb and reinstall lens cap.
May 21, 2010 | Cars & Trucks
THE BUTTON IN THE CONSOLE TO OPEN THE GAS CAP AND THE TRUNK WONT WORK AND I CANT PUT GAS INTO THE CAR!!!! IS THERE ANOTHER WAY TO OPEN THE GAS COVER AND THE TRUNK???
I can't promise it, but in my 99 A4 there is a release cable in the trunk. I have to pull the trunk carpeting away on the side where the gas filler door is, and there's a red cable there that can be used as a manual release. I imagine your TT has one as well - look in the hatch on the side with the gas door, and pull the lining back - you'll probably have a release cable as well.
Dec 17, 2009 | 2000 Audi TT
How do i fix automatic gas cap opener and trunk opener?
isn't there a MANUAL RELEASE CABLE in the trunk ? Check for a blown 20A fuse. Ck fuse around fuse # 22. Hope this helps
May 31, 2009 | 1995 Cadillac DeVille
Where is the gas cap release button on the 2002 boxster?
Passenger door there is a plastic ring when you pull it it releases the gas cap
Mar 21, 2009 | 2002 Porsche Boxster
Fuel cap and boot release buttons not working
I have a 2001 Audi TT Audi TT roadster, 87,000 miles. I love the car, but like all cars, things happen.
Open your checkbook, It is the command module , under your back glass, where the top goes , you will see a small door cut into the felt. Mine got wet and started a whole chain of events.
Seal that Window Good. 800$ repair to replace the comman module.
1. Windows were going up and down 1/4" all random times.
2. The Gas Release and Trunk Release buttons stop working
3. Alarm would go off at odd times.
4. Trunk would not open automatically.
To open the Trunk, behind the passenger seat is a small box, open it with you key and you will see the manual trunk release
To open your gas cap, on the passenger side of the trunk, you will see a small felt opening under the gas cap. Open it and pull back decently hard and the gas cap will open.
Good Luck.
Jan 05, 2009 | 2001 Audi TT
Gas cap release button is broken on 2004 kia optima
if you can some how manage to get it opened, spray some lubracant on the button inside the door. if not you'll need to replace the release cable.
Nov 29, 2008 | 2004 Kia Optima
Edmark steam brush
Hi
press small release button on steam supply cotroller lever and pull the lower portion towards you
. now inyour righthand is your water filling tank . open the cap 7fill baout 100ml of water & close the cap put this back to the main unit just by gently pressing towards to the unit
It is done nolw wait for 30 sceconds & start using
Thanks
Aug 03, 2008 | Vacuums
Brother GX-6750 Typewriter Logo
21 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
