Samsung bn41 I've replaced Samsung BN44-00264A Power Supply which blew a fuse, still no power to tv.Could it be my main board BN41-01149B?How can I check to be sure?
  • 3 Answers
SOURCE: samsung dvd v5600
Check D1SS16, a diode in secondary supply near the transformer. It's probably short circuit. Replace it with an SF-26, 400V, 2A rectifier diode, or equivalent.
Posted on Feb 20, 2008
  • 2318 Answers
SOURCE: Samsung Power Supply Board
The power supply part number is BN44-00159A. You can also download the info from this link. It's the service manual.
Posted on Jul 17, 2009
Cool_dud 09
  • 206 Answers
SOURCE: power supply board
Hai,
Please check on here....you will find it out!
Posted on Aug 23, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 8 Answers
SOURCE: CM 7000 will not boot up
On all units that I repair, I replace all nine of the power supply board capacitors regardless of the voltages. There are poor quality capacitors and are going to fail at some time in the future.
The logic board caps are the same through hole type as the power supply. Yes there are many surface mount capacitors but none of these have need to be replaced. Replacing the logic board caps are very difficult because of the inner plane layer that acts like a giant heat sink. I use a desoldering station that has a suction pump and set the temperature to 850 degrees F. First I unsolder the square pad lead as this one is easy. The other lead requires more time, I hold the iron on until I can move the capacitor lead and turn on the suction as I pull the part out of the hole. Even with this process the holes do not always come clean and require additional work. Without the desoldering station it is very difficult and I would not recommend attempting it.
Posted on Dec 04, 2011
BN41-01660B BN94-05068S SAMSUNG UE40D5520RKXXU MAIN BOARD
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 04, 2017 | Samsung Televison & Video
I have a faulty Samsung LCD TV and i would like help identifying the part of the TV that needs to be replaced.
like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 12, 2016 | Samsung Televison & Video
Sound no pic, replaced power supply still same problem
In most model Samsung LCD TVs, the T'Con board will be an integrated part of the display panel; and will be built in. If this is the case, it can't be replaced. Only panel replacement can be done. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2015 | Samsung BN94-02679D Main Board for...
I have a samsung lcd TV with a power board bn44-00264a. One day the TV just quit working even the red indicating lite does not work. I opened it and the 3.15a fuse, replaced it and blew again. Help!
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 24, 2015 | Samsung Televison & Video
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
Samsung LN32A330J1DXZA will not power on. Problem occurred after moving TV from one house to another. Samsung Capacitor repair came out and pronounced it a dead main board and did not perform any...
reset the c.breaker or replace fuse in the main panel service from your home 2) test the power cord 3) test the switch 4) see if the fuse or c.breaker inside is tripper or replace fuse and try again.
God bless you
Nov 03, 2013 | Samsung BN41-00965A BN94-02070A...
Power problem turning on
Shorted component/s on the main power regulator section. Check and replace
Aug 24, 2012 | Samsung BN96-23347A Main Board for...
What's your problem?samsung ln37d550k1fxza repair blown fuses
There is some shorted component/s on the main power regulator section. Locate them and replace.
My samsung ln52a650 blew a fuse during normal operation. one second it worked the next... nothing. popped her open and couldn't find any damage/arc/flash.... exploded parts. i hear this is a common...
U have all the tools and understanding basic electronic and also can do basic soldering?Yes.The tv power supply board,that the board,where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors components parts.It is usally have bulges or puffing up capacitors parts indication of components capacitors parts are dying and needed replacement.Replacement for those new capacitors component parts with the same Micro ferit and the voltages of those new components capacitors parts in a higher voltages like 5 or 10 voltages higher than the old components capacitors parts u are replacing for a better heat resistance for the tv operation of the tv power supply board for later on tv use.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 08, 2011 | Samsung LN52A650A LCD TV
A samsung 40'' mainboard BN41-00879A no video-no sound I have just bought a new mainboard ------Is there any ajustment on a new board.? or have I got a doa board??
SOUNDS LIKE YOU NEEDED AN INVERTER BOARD OR POWER SUPPLY INSTEAD OF A MAIN BOARD, UNPLUG THE CABLE FROM THE INVERTER BOARD AND SEE IF THE 24 VOLT LINE COMES UP, IF THE 24 VOLTS IS THERE AFTER YOU UNPLUG IT, THEN YOU NED A NEW PANEL, IF THE INVERTER BOARD IS NOT REPLACEABLE
Dec 30, 2009 | Samsung LE40M91B 40 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
