Question about Dryers
Says 'empty water' but empty - leave to cool and works again for 30 minutes?
My dryer is saying 'empty water' but it is empty - if I open the door and let it cool down it goes for another 30 minutes or so. What's wrong with it?
  • Dryers Master
  • 8,220 Answers
Might be a faulty water level sensor or it could be the sensor has some fabric softener on it.
Posted on May 20, 2009
I have a 05 Dodge Magnum I Drive it in like maybe 30 minute and it gets hot I let it cool off and it will start again
You need to check your coolant, and water pump, if ok then check your cooling fan. When the car gets hot, leave running, open hood and make sure fan is working
Feb 25, 2015 | 2005 Dodge Magnum
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
Ice keeps building up in freezer. Then the refrigerator stops cooling. You can get the ice off the vents in bottom back of freezer and it will start cooling again but only last a couple days before it...
Your freezer coil needs a good defrost. You are getting only a little bit of the ice off. It stops cooling because the ice acts like a insulator over the coil so it is unable to cool. Was to get this done is to empty it out and shut if off and leave the door open or maybe a hair dryer or even so warm water.
I hope this helps.
Apr 20, 2010 | Frigidaire FRT17G4B Top Freezer...
My Kenmore Elite HE5 Dryer beeps while running
Aug 14, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Freezer seal
Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
Thanks J
Feb 01, 2008 | Freezers
Dryers Logo
125 people viewed this question
Top Dryers Experts
