Question about Magnavox 32MF301B/F7 32 in. LCD TV
Screen is cracked - Magnavox 32MF301B/F7 32 in. LCD TV
Cracked screen
Hey Britanny,
once your screen is cracked, it's time to buy a new TV set. The cost to replace the screen will exceed the value of your set. Although the screen is cracked, it still has some value. List it on your local Craigslist and someone will buy it for parts. If this helps please sign my guestbook
http://www.back2lifeelectronics.com/Guestbook.php
Mar 20, 2014 | Samsung Televison & Video
37" full hd philips tv screen cracked because
If there is picture in the TV then probably it is the protective screen that has cracked and not the picture tube.Please check carefully.
Jan 20, 2011 | Philips Televison & Video
Screen looks cracked when unit is on, but it's not cracked outsid
have u tool it apart and see if it was cracked from inside!!!!!
Oct 06, 2009 | Sony PlayStation Portable (PSP) Slim...
Cracked Screen
cracked screen not can fix... junkout....
Sep 19, 2009 | Televison & Video
G1 screen is cracked
Cracked LCD screens are very common.They're just by nature,easy to crack. I would say,if your screen is usable ,and not particulary irritating,then just leave it as it is.But if you want a new screen and you want to know about repairing it, I can help you.
Jul 21, 2009 | HTC G1
CRACKED SCREEN
this might possess giving an arm and leg for new screen glass there might be a way to fix it and its a long shot
glass repair for auto mobiles that little filler they use for cracks is what i can suggest off hand
i hope this can be of use
May 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Cracked screen
I've had my enV for about a year, now. within the first month, I cracked its screen. I have both insurance and a warranty for it, but Verizon is unimpressed-- they suggested that I either purchase a new model, or perhaps buy the enV 2. it's whatever.
Feb 28, 2008 | LG enV VX9900 Cellular Phone
Crack inside of screen
This screen has multiple layers of plastic before you get to the main screen, if the picture isnt affected, you've only cracked oneof the plastic pieces, these are cheap to replace
Dec 31, 2007 | Philips 51PP9100D 51 in. Television
Sony Wega 29" TV screen cracked
Definitely this is due to thunder. Apart from rarely following type of problem occurs through vertical section also. Before you got the screen cracked past month or past week days you observe any rainbow color screen or single horizontal line in the center of the screen means there is a chances to crack. Unless otherwise any physical damage by any other person or the above mentions symptom there is no chances to crack the tv screen. Since it is not designed like that moreover this is SONY
Aug 27, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Open Questions:
See all Magnavox 32MF301B/F7 32 in. LCD TV Questions
Magnavox 32MF301B/F7 32 in. LCD TV Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
