Question about Samsung SyncMaster T260HD flat panel TFT 25.5" Monitor
Samsung t260hd firmware
Monitor constantly switches off and on. is there a firmware update or way to reset the monitor?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Go to menu of screen look for defrag or degause press once should sort it self out, if not onboard power supply is faulty of screen take to computer repair shop.
Posted on Dec 31, 2013
3 Suggested Answers
SOURCE: monitor turn off and on
there is no time to press remote keys.
Is there any other solution?
Please help...
Posted on Jun 23, 2010
  • 8 Answers
SOURCE: during a firmware update on my samsung S20A300B LED monitor the power was interupted and now to won't do anything.
The program has been distroyed, you need to replace flash chip on main board, (8pin SMT IC), if you can do it your self, go to www.daitech.ca, they might supply the chip with program. To open this monitor, use flat screw driver, there are only clips arround the bezel, no screw.
Posted on Feb 21, 2013
How to take apart
problem is in the flash light inverter logic card. the HT power choke is gone weak. replace this and also check the supply capacitors are conected to this circuit
Jul 04, 2014 | Samsung SyncMaster T260HD flat panel TFT...
My samsung sew-3030 won't keep the current date
To update firmware you will need a Microsoft Windows based PC and download the latest firmware on this website:
http://www.samsungsecurity.com/product/product_view.asp?idx=6404.
SEW-3030_mr8911isp-nor+spi_For US.zip (2.23MB)
Once downloaded, unzip files to your desktop and do the following sequence:
1st -> RUN file Generic_V1.0.0.0.EXE (USB firmware update driver)
2nd -> connect your wireless video monitor to power adapter
3rd -> press and hold select (enter) button in the middle of the dial.
4th -> connect USB cable to your PC. (screen will blank white instead of black) this is firmware update mode
5th -> RUN firmware update utility mr8911isp.exe , wait to USB connection (status bar will turn green) and show message ASIC: 0301 Device Connected
6th -> Press Update button and wait...
7th -> Update done! disconnect your device and voila! no more date/time issues and another bonus bugs fixed noticed: lower alarm beep volume, menu text size increased for better reading, temperature sensor more reliable
I Hope it help everyone having problems with this baby monitor
Jan 03, 2012 | Samsung Wireless Security Monitoring...
I need to remove the stand from my T260HD monitor
You need a table and a blanket spread on the table to prevent scratching the screen. Lay the set face down on the blanket and there will be usually 4 screws in the middle at the bottom facing up as the set is flat on the blanket that is holding the stand in place. Also sometimes there is a screw at the very bottom going up towards the top of the set.
May 24, 2011 | Samsung T260HD 26 in. LCD TV
How to setup my flat tv in the wall?
Any of the "big box" stores that sell large-screen LCD/LED/PLASMA TVs will also sell the wall-mount units.
Or, try 'www.eBay.com'.
Nov 14, 2009 | Samsung SyncMaster T260HD flat panel TFT...
Constant "busy" error and no display screen even if you push "menu"
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 12, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Camera is constantly buffering and virtually nonresponsive.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Aug 11, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Monitor screen shuts off and on while in DVI mode
First, try updating the ATI drivers. The DVI connection transfers information about screen state back and forth (it's a full two-way connection). If there's some bug in how the SyncMaster and ATI card do this communication (which sounds like the problem) then hopefully the newer drivers will fix it. Otherwise try it out on a RGB cable.
Jan 18, 2009 | ATI RADEON 9250, (256 MB) PCI Graphic...
Samsung SyncMaster T260HD flat panel TFT 25.5" Monitor Logo
512 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
