Question about HP LaserJet P3005n Printer
Screen shows ready but can't print
I have this printer as a network printer in the office, this morning it keep staying at sleep mode and dont response to our request. So I turn it on/off again and now the screen shows ready but the same problem, not responding to anything, it can still print a test page though....
Please help! Thank you!
  • benjaminh May 19, 2009
    I went to our server, clear the pending files on another printer, and 3005n gets back to work again. Thank you for your prompt reply.
  • Frank Zhang
    Frank Zhang May 11, 2010
    are you sure the network connection ok?
  • 184 Answers
Ese follow these procedures carefully and i hope it will solve your problem.
● Check that all trays are correctly
loaded, adjusted, and installed in
the device.
● Using the computer, check the print
queue or print spooler to see if the
device has been paused. If there
are problems with the current print
job, or if the device is paused, a
configuration page will not print.
Also check the IP address associated with it if it is not connected directly. Make sure it corresponds with the one on the printer.
Posted on May 19, 2009
Why does the Battery Drop so fast On Samsung tablets
mostly it depends on your usage, more the usage faster the battery drop.
In general, below are few ways you can reduce your battery drop.
1. keep screen brightness moderate or low
2. User power saver
3. dont keep your tab for charging for longer time, it reduces battery life (eg, you might keep it charging before sleep until morning)
4. Kill all background running apps when not needed
4. check your carrier signal strength, use airplane mode when there is not network
5. keep in sleep mode when you are not using (just hit lock button
Jun 23, 2017 | Samsung Tablets & eReaders
HOW TO STOP SLEEP MODE TO LEAVE PRINTER ONLINE
The are designed to sleep automatically but there might be a download on the Brother support site for a "Remote Printer Console" Are you mixing XP and Win7 documents into the que?
Mar 10, 2015 | Brother MFCL2700DW Wireless Networking...
4350 nosiy while in sleep mode
If it comes out of "sleep mode" every 10 minutes, and you haven't touched the printer or sent any data to the printer, try unplugging the LAN cable for 15 minutes. If the printer stays in "sleep mode"either the formatter is bad or whatever is on the other end of the LAN cable could be bad. If you can put the printer on another PC to see what happens, that would really help you out.
Jun 19, 2010 | HP LaserJet 4350 Printer
Canon IRC3200N warms up from cold when printing first job
One way is to leave the iRC3200 in standby mode and have one the office servers or office PC's to have ajob scheduled to print a 1 page startup job at 0835 so that the unit is ready for everyone at 0845.
Nov 12, 2009 | Canon iRC3100 Printer
Canon IRC3200N warms up from cold with first print job
Nov 12, 2009 | Canon imageRUNNER C3200 Copier
My printer canon ir2022n network printer does not print from my new vista business OS computer
Windows sharing based printers are dependent on the computer where the printer is attached. This means that if the computer is turned off, or is in the sleep/hibernate mode, then all the computers that can print through that server will not be able to print. To solve this issue you can use external print servers to share printers in the home/office. External print servers are connected to the router which allows it to be available on the network without being dependent on any other computer system. External print servers are available in both wireless and wired versions, and the choice between those options is based on the needs of the home or office.get more information and help for Network Printer Configuration .Hope this helps you.
Oct 13, 2009 | Office Equipment & Supplies
Printer stops working
have you set an ip address to your copier? made sure there are no cloned address (or other networking related problem) around? once you do access to the copier thru that IP address, simply type the address in your browser and you must access the RUI (Remote User Interface). From there you should be able to see your copier's status and everything. Make sure it is online and ready to print, and then unistall it from the computer and install it as a local printer connected thru a tcp/ip port. once you finish all that give a try and let me know.
Jan 27, 2009 | Canon ImageClass MF5770 Laser Copier...
Infrequent use of Xerox Phaser 8500
The reason he told you that is because ;
if left on permanently the fuser unit has a lamp ( nowadays the newer ones use a ceramic) the lamp continually comes on to keep the fuser warm and ready for you to print.which may cause the lamp to burn prematurely, most business keep theirs on all day with out the sleep mode( too busy to wait to warm up),
But, when you use the sleep mode most models do not turn on the lamp ( if it does it only puts out minimal power) but keep the power ready, which is why when you go to print it takes awhile to warm up.
The lamps are very resilient and last several years before having to change.
Jul 17, 2008 | Xerox Phaser 8500/DN Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
Feb 15, 2008 | Kyocera Mita KM-2050 Printer
HP LaserJet P3005n Printer Logo
366 people viewed this question
Seeker5211
Seeker5211
