Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Heat mode on trouble
By joybee on Oct 18, 2007
a.c works good in cool mode.when change to heat mode system geting off. compressor over heating.solinoid why  valve makes trouble in some units. can you expline its works in details.
Same Problem
Oct 26, 2008
-   Runs for about two minutes on heat mode and then warm air stops flowing but fan is still blowing room temp air-   Guest
Nov 27, 2007
-   reset botton on outsde unit trips on heat mode when unit starts when out side temp is abve 65 degrees-   billyray1
Best Solution
posted on Oct 23, 2007
Very Helpful)
BIKER T
Rank: Guru
Rating: 86%, 241 votes
Possibly changeover valve not functioning correctly causing high head pressure and  safety to switch off in protection mode.not the ideal DIY repair.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
on my window airconditioner I am constantly getting a thick ice buid up. I have cleaned the filters... (More)
Answer
I live in a manufactured home. When I turn on my heat on my amana it does not start.
Answer
I have an error code of CH 26 on my LG airconditioner 524AHN can you help me diagnose the problem.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
