Question about Fisher Digital New Tablet Pc Android 2 With Camera For Video Chatting 7 4 Inch
Will not boot up
Will not go past the android screen
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Sep 30, 2016 | Tablets & eReaders
Bypass security pattern on a Verizon 4G LTE pad?
Android systems can be full factory reset from the Android System Recovery menu.
For Recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
When you are in the Android system recovery menu, use The Volume Up/Down keys for navigation and the Power button for confirmation.
Choose one by one:
- wipe data / factory reset
- Yes -- delete all user data
- reboot system now
Nov 07, 2014 | Pantech Element 4G LTE Android Tablet
Maxwest tab-9155 won't load past android screen
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Tablets & eReaders
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
My daughter's zeepad will turn on but only to the screen that says "android". it will not get past this stage. I don't see any reset buttons or a way to access inside the unit to find one. What do
If a factory reset is required. Press and hold both Volume buttons and the Power button simultaneously; an Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate.
Jun 16, 2017 | ZEEPAD Tablets & eReaders
Zeepad does not open
can't get netflex to show picture.
Dec 29, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
Model q8(a-1) forgot password
Locked android. Forgot google account. Need to reset. How to do this and what buttons to use.
Jan 26, 2013 | Universal Q8 7"" Capacitive Screen Android...
Visual Land Connect Android 4.0 wont boot
Hold the power down and press the -volume button down to reboot
Sep 29, 2012 | Visual Land Connect Android 4.0 Internet...
Fisher Digital New Tablet Pc Android 2 With Camera For Video Chatting 7 4 Inch Logo
Top Fisher Digital Tablets & eReaders Experts
Are you a Fisher Digital Tablet and eReader Expert? Answer questions, earn points and help others
