Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
I have a Go Go Elite Traveller 4 wheel. I just spent $175 on 2 new batteries for it. I charge it every time I use it. It will not go more than 20 minutes before it stops. Then I get 6 beeps. According to the owners manual 6 beeps mean it has something to do with the throttle. But what? it was doing this before I put the batteries in. They told me the batteries were bad and that new batteries would fix this problem. It hasn't.
  • Pride Mobili... Master
  • 1,263 Answers
Hi, sorry to hear you having issues with the go go
Here's the manual
http://www.pride-mobility.co.uk/docs/Elite%20Traveller_owners%20manual.pdf
The fault description is :
Throttle control lever not at centre position
at start up.
Return the throttle control lever to centre
position, turn Travel Scooter off then back on
so what happened is that the throttle is no longer centre , look at the base of the throttle stem, a cross head , now that should look straight at the the seat stem, be in aligh with it, if's it off slight you will get that fault so you need to adjust the lever so the pot is dead centre again..
Still having a problem then goto my site and contact me so we can solve this for you free of charge..
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jan 01, 2014
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
gewiz
  • 1263 Answers
SOURCE: pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Posted on Jul 24, 2009
  • 26 Answers
SOURCE: i have a go-go elite traveller scooter and the
if light does not work fault in wiring or connection
Posted on Apr 15, 2010
  • 16 Answers
SOURCE: Go-Go Elite Traveller 17AH Battery Pack: whe I plug in my battery, the charge light doesn't...
You may need a new charger
Posted on May 21, 2010
wcdoc1953
  • 280 Answers
SOURCE: when I turn the key
The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Posted on Dec 23, 2010
Testimonial: "Awesome detailed info on how to fis/diagnose the problem."
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Need a repair shop to fix my gogo elite
This is due to the controller shutting down. Make the brake leverin the on position
Oct 08, 2014 | Pride Mobility Products Go-Go Elite...
Pride travel scooter cut s off
This is usually due to the battery "jumping" off the contacts when you go over a bump in the pathway. Put a RUBBER door stop between the battery and the seat post. This fixed mine for all but the huge potholes. Had this fix for 4 years
Aug 04, 2012 | Pride Mobility Products Go-Go Elite...
Can I buy new panels for a Go Go Elite mobility Scooter
Hi Tracy,
Yes, you can buy new shroud panels for this model in red, blue, and silver. Some of the panels, front, rear, side strip, and console, velcro on the chair and can be replaced by the end user. This is model SC54HD for the go go elite traveller plus HD 4 wheel scooter. For about $60 you can get the entire set of panels for a color change.
If I'm not mistaken some of these scooters come to our dealership with the extra panels already in the shipping box. This allows for a quick color change during dealer prep. Call around to several local dealers and see if they have extras available at no charge before purchasing new ones.
Jan 02, 2011 | Pride Go Go Elite Traveller Plus HD 4...
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
139 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
