Question about Kenmore HE2 Plus Front Load Washer
120v 60Hz plugged into 220v 50Hz outlet
There is a main board the power is connected to. I think the board is bad. When I turn on the washer everything works until I push start. The door locks but no water enters the washer. When I push the stop button the door stays locked.
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 17, 2015
4 Suggested Answers
duby1990
  • 367 Answers
SOURCE: my kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Posted on Nov 18, 2008
  • 107 Answers
SOURCE: Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Posted on Mar 13, 2009
cpldw48
  • 143 Answers
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
Posted on Apr 25, 2010
My relative send me a luxor tv its 50hrz..here in the philippines we use 60hrz.,is it possible and safe
is there no small slide switch at the back of the tv
10 volt difference
may need an converter to make up 10 volts
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
read this information on the 50 and 60 hrz
Difference between 50Hz and 60Hz frequency
Nov 02, 2016 | Luxor Televison & Video
WFW70HEBW does not power
hello guys, i have the whirlpool duet white front loader and its a 120v/60hz and its not powering up when plug in. my supply system is 110v/50hz. how do i convert it to operate on the 110v/50hz?
May 15, 2014 | Whirlpool Duet White Front Load Washer -...
Delonghi problems
Mains voltage in Australia is 230V 50Hz. Travellers from most nations in Asia, Africa and Europe should have appliances that work on the same mains voltage as Australia - therefore you will not need a voltage converter. Notable exceptions to this are Japan, USA and Canada which uses 100/120V 50/60Hz.
If your country does not use appliances within the 230V 50Hz mains voltage range, you will need to purchase a voltage converter. This will transform the voltage from the power outlet into one your appliance can use. You will also need a power adapter.
Dec 18, 2013 | DeLonghi Gelato GM6000 Ice Cream Maker
I have a Netgear wireless router WGR614 v5 with the AC adapter of 120V-60Hz-16W. I've moved to Europe where the electricity is 220V. Can I use an AC adapter of 220V for this wireless router? Thanks a lot...
Yes, make sure you have a new power supply with the right voltage output, enough current (if the new power supply is rated for more current output, it will be OK), and the right plug with the right polarity.
Check your power supply, some will actually work with a wide range of voltage, some actually go from 100-250VAC. 50Hz-60Hz
Jan 05, 2011 | NetGear WGR614 Wireless Router
Can I run a US bought PS 3 (120v 60Hz) unit on a 220v 50 Hz power system?
Yes you can,,as i am running Canadian bought ps3 in Pakistan 50hz 220v
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
Voltage difference
The voltage difference can be overcome. The problem will be the difference in frequency 50hz vs 60hz. The motors would have to be replaced with motors designed to operate at 50hz. The electronics would most likely need to be replace as well.
Best bet would be to contact whirlpool international to see if the offer a conversion kit/package.
Feb 02, 2009 | Whirlpool LER5636P Electric Dryer
Converting 120v AC adapter to 220v AC adapter
I live in the Philippines, but I've got relatives in the US who send me gadgets as gifts. I've had the same problem with my laptop before but when I called HP call center, they said that as long as it says there input 100 - 240V, then it's ok to plug it in a 110 or 220 socket. Here in the PH, we have 220V sockets, but Americans use 110.
Anyway, your phone says it can only be plugged to a 120V socket (max) so that means, you have to use a transformer (that's what we call it here. a black box-like thing) to convert the volts from 220 to 110. If you plug your phone directly, it might explode.
I hope i answered your problem.
Nov 27, 2008 | Lands Phones
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Kenmore HE2 Plus Front Load Washer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
