Question about Cameras
Singtronic ka-550 amplifier has lost power - Cameras
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
How do i get a free service manual download of a kenwood ka-127 model stereo integrated amplifier in any digital format?
I doubt you will be able to find a digital copy, and Kenwood dropped their home audio line 2+ decades ago. I probably have a hard copy of the manual, as I was a Kenwood Factory Service Center for over 25 years, however, it is not free. If you would like more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 11, 2014 | Audio Players & Recorders
KENWOOD KA-99 INTEGRATED AMPLIFIER MANUAL
Hi...
Does it look like this?
http://www.hifiengine.com/manuals/kenwood/ka-9x.shtml
Mar 27, 2010 | Kenwood Audio Players & Recorders
My kenwood ka-128 amp keeps randomly shutting off. what can i do to stop it from shutting off? Do i need more power?
you can calculate power needed as follows:-
amplifier power must be 20% more than the total power of all speakers(if total speakers power is 100 watt)you need amplifier of 120 watt at least more is ok.
Dec 04, 2009 | Audio Players & Recorders
My system has a ka-127 amplifier and i can only
lets go for the simple things first. Make sure that the unit is not in tape monitor mode. If it is in tape monitor, you are hearing the small amount of crosstalk present in any system.
Dan
Sep 10, 2009 | Audio Players & Recorders
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
