Question about FUJIFILM instax mini 7 Digital Camera
Unloading film its my first time ever with a instant camera and i was too excited so i think i put the film in the wrong way. I'm having trouble taking it out though and I don't want to ruin it.any suggestions for easy removal?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Did you get it out? If not make sure the lens pushed in then remove the batteries and the rear cover. Then try and pull straight out on film cartage, you may have try a little force but should come out.
Posted on Jan 01, 2014
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
My lomo fish eye camera won't keep the film in or reel it back
I have had the same problem with unloading film, i had to take the whole camera in to the shop to have them open it in a darkroom and develop the film. Seems will have to do that from now on but at least got film back.
Feb 23, 2010 | Lomo Fisheye 35mm Film Camera
How do you know if there is film in the camera and if so how do you know how many pictures are left to be taken .
I haven't heard of this camera, but most film cameras have a display somewhere that will show you how many have been taken. They don't usually show how many are left because film rolls can have anywhere from 12-36 pictures on them. If you are unsure about how many the roll of film had, you should assume it was a 24 exposure roll. 24 is the most common. If it doesn't have a number anywhere that you can see, you should take pictures until it stops winding.
If the film has been in the camera for a long time, it's probably better to just unload it and have it developed anyway. Film goes stale after a year or so for most films, so you may not have any good pictures on it anyway.
Hope this helps, if not make a comment with more information and I'll see if I can find a manual online for your camera. I'll need model number and as much more info as you can give.
Thanks
Sep 09, 2009 | Snap Sights SS01 Film Camera
I found an old poloroid instant camera and I thing
The battery comes in the same package of the film, altough there's no new film been mada AT ALL. If you find one buy as much as you can. There's no battery and no where to put it besides with the film.
Jun 26, 2009 | Polaroid 600 Business Edition Instant...
I do not know how to load or unload the 35 mm film.
The cartridge will only go in one way. install and pull film to marked line (should have a few notches in the film strip past gear) close camera and either wind until it stops or if batt powered it will load itself then ready to roll
May 23, 2009 | Photography
Cbnnot close camera after unloading film
Unless you are sure it is broken, it may not need repair. Have you looked in the manual ? Should repair be necessary, the price will probably be more than the cost of a more up-to-date replacement
Nov 09, 2017 | Canon Sure Shot Z155 Caption 35mm Point...
Polaroid One Step Camera
whitehall-bo,
give it a try, the batteries come with the film,so if it was stored high & dry it's probably good. polaroid pack should still be around. they stopped making polaroid camera's and film.
Nov 18, 2008 | Polaroid OneStep AutoFocus Instant Camera
Unloading my medium format camera
If i remember correctly there should be a button on the bottom of the camera opposite side of the film winder if you press that button it will release the tension on the film and allow you to reel the film back into the film canistor.BE CAREFUL when reeling it back in because you can reel the whole roll back into the film canistor, when you think your getting towards the end go SLOW you will feal the reel loosen up alot.that means that the film has let go of the other side STOP and you can open the case without exposong your film.GOOD LUCK if this helps rate me or leave some more info.Thanks.
Nov 18, 2007 | Photography
Leica m6 film stuck, I think
Did you mean you wanted to unload the unfinished film?
What you did then? be more clear and specific about the procedures before I can give you suggestions.
pc-cook
Oct 22, 2007 | Leica M6 TTL .58 35mm Rangefinder Camera
FUJIFILM instax mini 7 Digital Camera Logo
65 people viewed this question
Top FUJIFILM Cameras Experts
Steve
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
