Question about Dishwashers
KitchenAid KUDL40CVSS dishwasher during the wash cycle stops intermittently then starts again. Not sure if this is normal. Don;t remember it doing it before.
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 185 Answers
SOURCE: Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Posted on Mar 28, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
wolfpackicu
  • 26 Answers
SOURCE: Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Posted on Jul 30, 2009
How do I reset my KitchenAid Model KUDS35FXSS1
The unit normally has a 1:20 to 1:30 fill cycle with pauses in between while the wash motor starts and stops without running a diagnostic mode this normally happens when the control outputs power to the wash pump motor but the pump doesn't start
Sep 13, 2014 | KitchenAid Dishwashers
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
Kenmore dishwasher stops midway through
http://fixitnow.com/wp/2006/03/29/whirlpool-kitchenaid-kenmore-dishwasher-poor-cleaning/
Here is a good page that can help you resolve this issue and buy the parts needed
Feb 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Squeeking during wash cycle
Hi jbramwilliam
I'm Harvey the Master Plumber.
Sometimes this is caused because something is now rubbing. Make sure:
The screws are secure to the counter,
The d/w is perfectly level,
The legs are all tight to the floor,
If the back legs are wheels then shim with wood blocks.
If it still squeeks then you have a warranty problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | GE PDW8200NWW / PDW8200NBB Dishwasher
Noisy Dishwasher
Mar 28, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
