Question about Garden
Noisey gearbox when I put my rototiller into gear it clunks & it's noisey
    Sniper:
  • 57 Answers
Check the oil level in the gearbox. After that the process will be looking for a probable bad bearing or gear.
Posted on May 19, 2009
Noisey gearbox
Do u have the right gear oil in it put some 90 weight in it , could have bad main shaft bearing
Jan 30, 2014 | BMW F650GS Filler cap. Filler cap; Fuel...
Kawasaki ZZR 600 clutch noise
Hi, Tompolv6 I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Gears---WHINE
10. Head Gasket---HISS
11. Hydraulic Lifters---TAP
12. Pistons---SLAP
13. Rear Shocks---SQUEAK
14. Shifting Trans---CLUNK
15. Solid Lifters---TICK
16. Starters---CLICK
17. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
03 zzr600 Loud clunking noise at idle
zzr600 clutch noise
Kawasaki ZZR 600 Complete Service Repair Manual Download Manuals Technical $10
OEM Parts for Kawasaki
2006 Kawasaki ZZR600 Owner Manual
May 25, 2017 | kawasaki ZZR 600 Motorcycles
Fiesta started making noises either gearbox or clutch? clunks going in to reverse, shudders driving off in 1st gear
sounds like your clutch is going out, is it hard to put in gear with clutch all the way depressed? could also be the sinkronyzer going out, could be the gears in the transmission also going bad. need to check the fluid in the transmission.
Feb 11, 2011 | Ford Fiesta Cars & Trucks
2005 Corolla's manual trasmission shifts gears, it clunks
hi mate , sounds like the SPIGOT bearing its a little bearing that allows the gearbox to be at a different seed than the engine flywheel and if this is in bad condition it will take the gearbox front shaft to a higher speed than comfortable for gearshift , in the meantime when you go for 1st or reverse gear just engage a gear like 4th without taking your foot off the clutch and then go for 1st or reverse, this will stop the gearbox spining long enough for a smooth shif, oNLY USE THIS METHOD WHILE STaTIONARY and see a professional when you get time.
Mar 29, 2010 | 2005 Toyota Corolla
5 speed manual 91 4x4 gear noise in 1,2,3and 5th gear, 4th gear no noise.
do get like a clunking sound shifting between first an reverse as you let the clutch out?.if so its probably a universal joint either the one up by the tranny or the one by the rear axle.
Nov 14, 2009 | 1991 Toyota Pickup
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Noisey gearchange
Hi Al,
I know you are looking for feedback and I hope I can help.
I have a FLHR Road King Harley Davidson and believe me It clunked real bad when I bought it (7,000 miles), I checked the clutch primary chain, well within tolerance, also Clutch plates too.
I know your engine is wet sump and the gearbox uses the same oil as the engine?
I changed my gearbox oil and also double checked level as the amount that came out wasn't enough?
Since then pure smooth cold & Hot, so maybe the wrong viscosity oil? Nice & Thick cold but when thinned due to warm up and at operating temp not coating the gears so bulk rings failing slightly?
There you go one to look at?
Press the Blue Button please to appraise my FREE! Effort/s, Thank You!
Paul 'W' U.K.
Feb 16, 2009 | 2000 kawasaki ZZR 600
Gearbox on 1999. 1.6 megane sport.
renault gearbox are known to give problems.the clunk you hear might not be in the gearbox sounds more like gearbox mounting i would get it checked first however the whine in fith gear is a differant problem yes i am inclined to agree with you on this one.sorry but it looks like a replacement gearbox is going to be the only answer good luck.adrian
Feb 14, 2009 | 1986 Renault Sport
04 Sportster 883 gearbox Clunk.
Big Twins clunk too, especially into 1st with a cold motor, even if you free the clutch off first. When I remember, I snick it into gear, pull in the clutch and roll it back and forward to free off the plates. And it still clunks. Sometimes, you will slip from neutral into 1st, almost with no effort, and no clunk and so smooth you don't believe it's engaged (but it is). Weird. I have smooth changes from 4th to 5th and back again, sometimes from 3rd to 4th, but 3rd to second and second to 1st are always a BIG clunk, even if you give it some stick to try and match the revs before changing down. I now go from second to neutral and then into 1st, which is not a lot of fun when you are negotiating a hairpin on Glenquaich at the time... A tighter primary chain seems to reduce the clunk, and there are those who say that auto primary adjusters/tensioners (does a Sporty have one of them?) reduce the clunk. Some disagree... Assume you find it's much better when it's hot..
Nov 20, 2008 | 2007 Harley Davidson XL 883 Sportster
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
