Question about Samsung HF1000 Bluetooth Headset
Power cycles on off
The device goes power on connected then almost immediately goes power off. This occurs several times then it seems to settle down for a short time and the the cycling starts again.
SOURCE: Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Posted on Mar 12, 2009
komguy
  • 2306 Answers
SOURCE: System Error Cycle Power
That error is not listed in the manual, could be a fuser problem, sensor problem, or the main PCB is defective. They have a one year warranty, hope it's still within that period!
Posted on Jul 16, 2009
  • 304 Answers
SOURCE: LN-T4061F Goes black after a couple of minutes.
The T-Con bd is probably going bad. Also the Main bd could be bad. Have a trained samsung tech troubleshoot the set.
budmrtn
  • 11361 Answers
SOURCE: syncmaster 203B LCD Monitor Black
Check for bad caps, see example here: http://s807.photobucket.com/albums/yy352/budm/Samsung%20203B/
Posted on Jan 08, 2010
  • 784 Answers
SOURCE: The laundry is still wet after a normal wash cycle
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Posted on Jan 09, 2010
Frigidaire dishwasher stops in mid cycle
two things to look at : water level sensor ? seems I once had a machine that the water inlet valve never totally shut off and it overfilled basin this shut machine off on a spill sensor fault but took several minutes to do this , Also the door closed switch , seems they do get finicky as time goes on and even thought door stays closed the movement of machine opens the door switch up (not the door) this also takes several minutes to occur
Sep 02, 2015 | Frigidaire Dishwashers
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
Flashing lite on router
If there is no connection problems a flashing light may simply mean that there is activity. If you are also experiencing connection problems refer to the next paragraph.
Most problems that occur on a router require power cycling the device several times. To power cycle you want to unplug the power connector for 10 seconds, plug it back in, and it should begin powering.
Mar 03, 2011 | Belkin Basic Wireless Router
Richmond LP PowerVent water heater stops heating. LED's A&B, indicating it has cycled three times without ignition. Watching it go through its cycle, the heat plate glows, hear a click, no flame,...
just an educated guess but id say you have one of two possible problems , gas valve bad or flame proof device is bad
the second cause is very common !! so common in fact theres a spare hanging on the side of mine !!!
May 27, 2017 | Rheem Water Heaters
When I shut down my computer my hp 4470c scanner switches on and the power button is unable to switch it off
There could be several reasons for this issue . It is not recommanded to leave hard drive connected to power when not in use . You should pull of the power plug after shutting down your pc and give it another try after reboot .
Maybe you have updated your OS and there are no more drivers available , like with Vista or W7 .
Try also by deleting driver in Device Manager and software in Control Pannel \ programs . Unplug device , reboot , reinstall sofware driver , reboot , wait for OS to be settled , connect scanner and wait for confirmation of successfull operation .
Regards
Aug 05, 2010 | HP Scanjet 4470c Flatbed Scanner
Incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Apr 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
Our well pump went out and was replaced, there has been some silt from the well and we have cleaned the water filters in the lines. when the washer goes into the rinse cycle, the water goes down to a...
Sometime there are water screens in both the hoses and the water vavle. Given you mentioned that in the rinse cycle the problem most often occurs it seems you still have cold water clogged screen issues. Turn off your water hoses and remove them at both the water valve and the hose bibb faucetts. Remove and Re-clean the screens under running water with an old tooth brush. It is not uncommon for a water system that has had silt intorduced into it to cause water fill flow problems for quite some time. That silt has settled in your pressure tank and your hot water heater. I would recommend that you attempt to drain and re-fill them both to at least minimize further silt introduction. In the mean time clean your inlet screens in the water lvale and hoses as often as necessary until the problem goes away.
Jan 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Samsung HC-R4755W 47 in hdtv will not come on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 27, 2017 | Samsung HC-R4755W 47" HDTV
"POWEROFF" display comes up randomly
there may be broken soldering points in the receiver take it to a workshop or open it your self and check it on the power source
Jul 02, 2007 | Pioneer VSX-D509S Receiver
Samsung HF1000 Bluetooth Headset Logo
21 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
