Question about Ricoh Office Equipment & Supplies
Ricoh stuck scanning processing - Ricoh Office Equipment & Supplies
2 Suggested Answers
  • 32 Answers
SOURCE: i want scan a page from ricoh aficio mp2500.how?
first install twain driver to ur pc and just open the microsoft world and go to the insert tab and then selct picture then 'from sacanner or camera'
or goto start-programs-microsoft office tools-documebt image scanning
Posted on Apr 23, 2010
Ricoh wide format MP W3600 stuck "processing"
Check the transfer unit or charge unit is not arking or one of the wires is out of position causing arking
Nov 16, 2017 | Ricoh Office Equipment & Supplies
Need to know how to send scan to email on the alfio ricoh 2051 printer?
It's quite a lengthy process to achieve this.
Best would probably be to open an Internet Browser and type the IP Address of the printer into the address field. You will have to login to be able to administer the printer.
It is usually much easier to do the configuration through the web interface, than on the user interface directly at the printer.
The following link points to the printers manual: http://support.ricoh.com/bb_v1oi/pub_e/oi/0001027/0001027282/VB1416700A/B1416700A.pdf
See page 75 "Email Destinations" on how to configure an smtp server and email addresses.
Hope you get along with the manual and good luck.
May 09, 2011 | Ricoh Computers & Internet
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Ricoh 3235 scan to eail will not work
for this to go to email you will have to enter the administrators email address the document is going through this can be found by going into the user tools(123 button) then system settings and file transfer at the bottom there is a tab for administrators email address enter it here and it should allow the emails to got through.Good Luck
May 08, 2010 | Ricoh Aficio 2232C Color Copier
I want scan a page from ricoh aficio mp2500.how?
Apr 23, 2010 | Ricoh Aficio 2015 Copier
Hello: I started scanning some documents through the machine's feeder and suddenly it just stopped and now is stuck in processing mode. It won't let me stop the job, not even turn off the machine. Please...
What do you mean, you can't turn off the machine? "red" button on front cover, or unplug it...if it doesn't turn off that way, then you really have a problem! maybe even a haunting!
Jul 15, 2009 | Ricoh Office Equipment & Supplies
Trying to scan w/ Ricoh Aficio SP C210sf
Could be a driver issue. Go to: http://www.ricoh-usa.com/downloads/software.asp?tsn=Ricoh-usa and find, download and install the driver for your Ricoh device.
Jun 11, 2009 | Ricoh Aficio SP-C210SF Printer
105 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
