Question about Mitsubishi WD-73642 3D DLP Home Cinema TV
My mitsubushi WD-73642 model keep flashing green when i turn it on,then the green light would be on steady, but the tv would not show a picture, then the light would go red? iI tried resetting it by pressing the lfeft, right arrow,and power button all at the same time, and all it would do is reset but i get the same results. what could this be?
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
Slinteriors
  • 8617 Answers
SOURCE: WD-65833 Flashing Green Light/Will not turn on!
its an easy repair however i would recomend not even attempting the repair without the service manual as the DLP chassis is completely incased and you will need the info just to get the chassis out , That will explain exactly how to disassemble. once disassembled there are 4 100uf capacitors that are causing the problem. If you would like the full service manual for your set let me know and I will post a link where you can get it emailed and they will provide free support to help you do the repair.
Posted on Mar 29, 2008
patopato
  • 3 Answers
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Posted on May 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: i have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blin
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
Why does my status light blink green then turn solid red with no picture
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 14, 2014 | Mitsubishi WD-73642 3D DLP Home Cinema TV
No color on my mitsubishi wd=73642
Check its picture settings. Especially to system settings.
Jan 16, 2014 | Mitsubishi WD-73642 3D DLP Home Cinema TV
Green light flashing on TV. Cannot get it turned off. No pictur
Did you get yours resolved? I had the same thing. The repair guys called it the "flashing light of death". It indicated the TV is dead.
Jul 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
Mitsubushi wd 52525 No picture, no sound. Self Dia shows 1.2
No trouble code is 12, is that what your getting? Is red light on all the time or blinking?
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubushi code 59: "DM short detected"
yes it sounds like it.
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Feb 08, 2008 | Televison & Video
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-73642 3D DLP Home Cinema TV Logo
241 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
