Question about Vizio L32 32 in. LCD HDTV
How to reset lg motel model tv
Got from motel sale,can't pull up program channel mode & audio will only go to 37 on bar wich is only half volume
  • Vizio Master
  • 9,742 Answers
Go up on Visio's web site. They can tell you what the steps are to get to the special setup screen on the TV.
Posted on Jan 06, 2014
Motel tv broken trying to hook up my own
1st I hope the motel is giving you a discount for a room with no tv , second an educated guess would be that your tv is non digital and is set to receive an antenna signal , along about three years ago most all cable systems went to a digital system , this required a down converter for the older TV's to still be able to work on higher channels but some systems still sent 2-13 out on the wire for the older sets as well , essentially the converter takes a hi res digital signal and changes it to a fuzzy/blurry analog signal for the old tv's , silly as it sounds , there's millions of em working everyday in America that way
Feb 26, 2016 | Panasonic Televison & Video
I have a LG 32ld333h tv it won't auto tune and doesn't have a add/delete how do i get it to program channels
You sir have a hospitality tv used only in hotels and motels proidium tv type that needs a master remote or call best buy to reset to consumer type tv from commer
Aug 25, 2012 | LG Televison & Video
Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Jun 14, 2009 | Vizio L37 Television
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Audio out of sync with video on LG 37 LCD
Do a factory reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 07, 2017 | LG 37LC7D 37 in. LCD HDTV
I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Dec 13, 2008 | Zenith C27A24T 27" TV
I have an audio problem LC-26d43u
What's "everything"?? Have you looked at the audio menu to see if you were on SAP (second audio program).. Being in SAP could affect one or more channels that do not broadcast in SAP mode.
Bill
Nov 13, 2008 | Televison & Video
LG 37
You can read the owners manual and do a channel scan to memory.
If you mean that just the first 13 channels are all you get, then you have to change from AIR to Cable or STD mode (again, read manual).
Sep 08, 2008 | LG 42LC2D 42 in. LCD HDTV
42PF9630A/37 Phillips Plasma HD
It is set to Cable.
There is no 'sound' of volume bar.
It is almost impossible to get any volume out of the TV sometimes, then it starts blaring.
Piece of junk.
Feb 03, 2008 | Philips 42PF9630A 42 in. Plasma Television
Vizio L32 32 in. LCD HDTV Logo
70 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
