Question about Boating
Yamaha outboards troubleshooting
Won't start
    Sergeant:
  • 456 Answers
Need lots more info,check fuse
Posted on Jan 01, 2014
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
Outboard will not start tried changing spark plugs,fuel filte,r clean fuel
Top 25 Reasons Your Boat's Engine Won't Start ' Boating ...
www.boatingmag.com/.../top-25-reasons-your-boats-engine-won...
BoatingAug 10, 2012 - A list of things to check for outboards, inboards and sterndrives. ... Top 25 Reasons Your Boat's Engine Wont Start. Even the mood created by ...
Basic Trouble Shooting When Your Outboard Won't Start ...
? 2:18
https://www.youtube.com/watch?v=hZGfjNzdT9U
Feb 23, 2014 - Uploaded by boats.com
... on basic troubleshooting when your boats outboard won't start will help you get ... Outboard won't crank or turn over, electricstart not working ..
Nov 23, 2015 | Boating
I need the torque specs for the big ends, crankcase and cyl. head of yamaha 90 outboard 1996
This will be a good source of info for Yamaha outboards: http://www.marineengine.com/boat-forum/forumdisplay.php?37-Yamaha-Outboard-Forum
Yamaha Outboard Forum
Jan 25, 2014 | Motorcycles
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
I need a carb diagram for yamaha tzr 250 cc motor cycle year 1988 it will not rev with out choke on . blocked jets?
Hi, Rolandwhitfo and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
TZR 250 WON START
Will start but wont stay running without choke Yamaha Outboard Parts Forum
Yamaha TZR250 1987 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Aug 08, 2011 | 1988 Yamaha TZR 250
Yamaha outboard 150 4 stroke bad vibration at 700 to 1200 rpm run great in nuetral and over 1200 rpm what could it be
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 03, 2009 | Boating
Yamaha outboard starting
New plugs and service
Sep 21, 2009 | Rock & Ice Climbing
Boating Logo
85 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
