Question about Plumbing
Banbury lost instructions for model 87690SRS - Plumbing
We had a £15 99 meal from you banbury shop we dit hot get wate we piad for
you failed spelling also. this is not a complaint desk or didnt you know this???
Oct 15, 2017 | Health & Beauty
Remove moen banbury faucet handle
set screw on side of handle hex wrench
Dec 04, 2016 | Moen Plumbing
Hot water is leaking from the spout of Banbury ca87000 sink
The filter on the tip is clogged and loose
Nov 17, 2014 | Plumbing
How do I fix hot water handle that is leaking on Moen Banbury ca87000 sink
The valve cartridge needs replaced. Those can be purchased at most home improvement stores, such as Home Depot. Or, it may be under warranty.
http://www.moen.com/replacement-parts/search
How to fix Moen Banbury model 87690SRS kitchen faucet ?
There is no way to tighten spout from top of sink. If you slide in cabinet and look up at the bottom of the faucet (spout ) you will see a nut on the threaded shaft of the spout hanging below in cabinet. With a basin wrench, kind of like a spring loaded pair of channel locks with a long extension arm and t-handle, you get it around the nut and tighten it clock wise on the shaft. You may have to disconnect the faucet valve ( handle part of faucet) from the bottom of the spout before tightening. Note...be sure that the jaws of your basin wrench are firmly around the nut only as not to mar and gouge the threads on the spout shaft. It is also helpful to have someone else hold the spout in position at the top side in order to tighten it properly. Some of the moen models (depending on place of purchase) may have a nut with set screws in it. You get the nut as tight as you can by hand and with a screw driver tighten the screws which will be visible and the heads will be facing down at the sides of the spout shaft. If you can't seem to locate what I am describing post again and I will try to locate a diagram for you.
Apr 26, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
How do i remove the collar from the two handled kitchen faucte?
You may need a rubber strap wrench to remove the collar,they are not that expensive.
Jun 02, 2011 | Moen Banbury Collection 2 handle Kitchen...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
