How do i connect my kenwood vr-255 to my sharp aquos model lc-40d78un ?
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Posted on Aug 01, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Posted on Dec 18, 2009
SOURCE: I need the 4 digit remote code for a Sharp Aquos
Try 0093 mate.....
Rgds,
Nik..
Posted on Jul 24, 2010
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
Jun 09, 2014 | Sharp LC40D78UN 40 in LCD TV
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Connecting an hd-tv
use optical or composite digital audio cable only from tv to receiver because with rca (red and white) you get stereo only
Jan 11, 2009 | Kenwood VR-616 Receiver
Cant get the wiring figured out.........
I have a similar set up. For yours, I would run one optical from your Sat box to your 407 and connect the DVD player optical to the Kenwood as well. This will allow you to get whatever your watching, DVD or Satellite to your speakers. For Video, use the component cables to connect DVD player to TV. For the SAT box, coaxial to TV or S video to TV will give you about the same video quality. I hope this helps. A couple of suggestions: Your new screen size will greatly magnify the quality of your video, what looked good on the Sharp may not look good on the Samsung due to the size difference. I REALLY suggest you get a new SAT box with a HDMI connection. Also you can get a blu ray player in the $120 range. The Blu ray will play blu rays and upconvert DVDs to a higher quality picture through its HDMI connection. You will be amazed at the difference HDMI will make on how your TV will look!
Oct 29, 2008 | Kenwood VR-405 Receiver
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
