Error message 010060
My Designjet 755CM was not recognizing yellow cartridge cleaned contacts, purchased new cartridge then was saying install color cartridges. Finally got it to go to calibration. When finished error message 070000 00000001 came up then after a couple of minutes that went away then got error message 010060 trying pushing the enter key as stated on HP site that would do nothing. Finally walked away came back to printer in about 30 minutes and printer had powered off. Please advise what this error message means and how to correct. Arleen
  • 1 more comment
  • afencl May 20, 2009
    The printer was not recognizing the yellow cartridge we cleaned the contacts finally purchase another cartridge even through the cartridge in the machine was hardly used. Then the machine went to saying install color cartridges, after taking all the cartridges out again, then the black went to flashing replaced the black cartridge. Then the machine started calibration after finished the 070000 00000001 message came up I had this message previously in trying to get machine working. I waited a couple of minutes then the 010060 message came up, I then pressed the enter key that did nothing. I waited a couple more minutes then walked away from printer, came back about 30 minutes later and it had powered off. I tryed pushing power button and nothing happened. I then went to the HP site of find out what this error message is. I am using HP cartridges. Arleen
  • afencl May 27, 2009
    Is there a fuse in this printer that could have blown when the 010060 error message came up?
  • JDTec
    JDTec May 11, 2010
    Are you using HP cartridge?
    070000 00000001 is a Yellow cartridge error.
    SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
  • 4,338 Answers
There is no mention of a fuse in the index.
I just read the manual and the SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
I uploaded the manual for you, here is the link:
http://rapidshare.de/files/47323187/HP_DeskJet_70-75-755_Service_Manual.pdf.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 27, 2009
  • JDTec
    JDTec May 27, 2009
    BTW select free on the bottom right side of the download page. It is a free site, so you have to wait till the counter counts down. but it works.
    Joe
Black ink cartridge is not registering as being in machine after changing
1.The carriage contacts are worn out and the contacts need to be replaced.
2.The Trailing cable is worn out and needs to be replaced.
It is highly recommend that you replace this both at the same time.
These are the two likely causes of the cartridge problems.
You can do it your self by following the service instructions at http://www.feedroller.com/store/Service%20Manual/DESIGNJET%20700,%20750C,%20750CT,%20755CM%20Service%20Manual.pdf
and you can get parts at http://www.donparts.com/products/53-DJ-700-750C-755CM/ for the plotter.
Jun 14, 2012 | HP DesignJet 755cm InkJet Printer
HP designjet T610 yellow cartridge error
If its yellow cartridge error, replace it, if "resit yellow cartridge" error, >check cartridge contact unit in iss unit,>inter change with another cartridge contacts unit & try for the diagnosis.> replace iss PCB..
Jan 04, 2012 | HP DesignJet 1050c plus InkJet Printer
I was installing the yellow ink and then all the sudden after I installed it the message Error Oxc18a0301 appeared! How do I fix this?
Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color.
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or re manufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts (1) - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge
Nov 24, 2010 | HP Photosmart C6280 Printer
Cartridge problem for 755CM
Dec 21, 2009 | HP DesignJet 755cm InkJet Printer
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Error message "Color cartridge missing"
sounds like you got one with a faulty chip, take this back to where you got it from and they should replace without any problems.
Oct 05, 2008 | Dell 924 All-in-One InkJet Printer
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Sep 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
394 people viewed this question
k24674
jasbo
jasbo
