Question about HP Computers & Internet
Windows 8.1 is frozen in safe mode boot with network.
I cannot return to a normal boot. I just have a blue screen with power button and a couple of options I do not need.
    Scholar:
  • 143 Answers
Go ahead and boot up in current safe mode. Log into Windows. Goto Control Panel/System and Security/Administrative Tools. In the list is a selection for SystemConfiguration. Dbl-Click it to activate. On the General Tab select "Normal Boot" then click the Apply button at the bottom. On the "Boot" tab, Remove the Check Mark from the "Safe Boot" box. Click the Apply button on the bottom and Click OK. Close everything and Re-Boot your computer. Should boot up to normal Windows.
Posted on Dec 31, 2013
Testimonial: "Sorry about the long wait for a thanks. The process you had given worked like a champ. Thanks for the answer. Your wisdom has been expanding to all!"
4 Suggested Answers
  • 131 Answers
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
Posted on Apr 30, 2008
  • 71 Answers
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
Posted on Jul 25, 2009
parrotheadpc
  • 2600 Answers
SOURCE: black screen folowing options. safe mode etc. asus Eee pc 904hd
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Jan 18, 2010
How to boot up computer in safe mode.
Now to get to safe mode, is a couple different ways depending on your OS.
For Windows 7
  • During boot up, press F8 before the windows splash screen, this should give you the option to boot up into safe mode.
For Windows 8
  • Open up the charms bar
  • Click Settings
  • Hold Shift before pressing the power icon
  • While still holding shift, click the power icon
  • Keep holding shift, and click restart
  • You may release shift
After restarting Windows 8
  • Once the PC boots, you'll see a screen that says "Choose an Option"
  • Click "Troubleshoot"
  • Click "Advanced Options"
  • Click "Windows Startup Settings"
  • The computer will restart
  • When the computer turns back on, you'll have the option to boot into safe mode.
Feb 14, 2015 | Computers & Internet
Laptop frozen on logging off mode, can't access anything
Have you tried starting in safe mode to see if it will boot that way? In case your not sure how turn the computer off then when off hit power on and just start pressing F8 over and over until you get the black screen asking about safe mode. You might hear some beeping while doing it dont worry about that. Choose start in safe mode with networking.Quick question is there any reason the lapshows the screen of windows starting vertically like that instead of the normal horizontal way from left to right? Just curious if you did that or thats new too.
Feb 05, 2013 | Computers & Internet
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
WHERE DO I FIND SAFEMODE IN HP
As soon as you boot up the laptop, press the F8 function several times and you will get a Windows menu where you can then select boot up in Safe Mode.
May 18, 2012 | HP Computers & Internet
Blue screen tells me to disconnect driver. New hardware sign comes up then get blue screen. Restart and press F8 but blue screen returns
f-8 will get you into safe mode,that is basic boot minimum periferals,i would go into safe mode delete drivers,reboot normally and follow instructions for install.good luck!
Jan 08, 2011 | Western Digital My Book Essential 1TB...
When I boot up my laptop, it asks me 4 options. Start windows normally, safe mode, safe mode with command prompt, and safe mode with network support. It doesn't matter which one I pick, but when the laptop...
To start your computer normally you must choose either of that options but the only thing you must choose is the start windows normally so that all the settings from the previous working settings will be applied in your windows start up.
Dec 25, 2010 | Toshiba Satellite L45-S7423 Notebook
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or...
did you recently install a new hardware ?
did you recently install a new software?
if you answered yes to any of these questions above you need remove it.
therefore if you installed a new hardware safely shut down and remove cables and remove hardware.( if it is hardware the hardware is not compatible with windows)
if it a software boot in safe mood then uninstall software. ( to boot in safe mood, press F8 while computer in turned on )
Sep 27, 2010 | NEC VALUESTAR T (VT900/8D) PC Desktop
Frozen screen
try to log in safe mode when the laptop is booting by pressing F8 key, you will see many option select boot in safe mode, if you can boot in safe mode then reboot normally. if the problem remains then you have to repair or reinstall your operating system.
Dec 15, 2008 | HP Pavilion dv6000z Notebook
Cant start windows
The no bootable device found or the promary disk not found error can be caused because of the following reasons
1. The operating system has crashed
2. The harddrive is faulty.
Try the following steps
1. Remove any cd if there is in the optical drive
2. Disconnect the Ac adapater and remove the battery
3. Press and hold the power button on the laptop for 10 seconds
4. Reconnect the Ac adapter
5. Power on the laptop and press F12 key on the keyboard a couple of times slowly on the Dell screen
6. Select Hardrive diagnostics from the list
7. If the harddrive returns with an error code , you would need to replace the same
8. If not then, restart your computer and press F8, a couple of times on dell logo screen
9. Select safe mode from the list.
Use the following wizard
http://tinyurl.com/56ym45
Thanks
Proton
Nov 19, 2008 | Dell Inspiron 700M Notebook
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
