Faulty universal remote control
I have a RCA universal remote but am not sure how to lock the codes in.I tried enter after each code entry but nothing works.I have to keep resetting the codes like every five minutes and its quit annoying.I need to know if it can be helped or do i have to but a new remote control.
  • 393 Answers
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on May 21, 2009
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
Tip
RCA Universal Remote Code Entry Models RCR312W - RCR311BN - RCR311BIN RCR311SN -...
RCR311SN - RCR311STN
Would you like help entering the code to program your RCA Universal Remote? You can look up the codes for your remote on this list.
Here are the steps to enter the programming code into your RCA Universal Remote:
  1. Manually turn on the device you want to control.
  2. Find the Code List. Locate the section for the type of device you would like to control and find your brand in that section. Write down the code(s).
  3. Press and hold the device key you want to program. The on/off key light comes on.
  4. While holding the device key, use your other hand to enter the first five digit code for your brand from the list. The on/off key light goes off after the first digit.
  5. When finished entering the code, keep holding down the device key and look at the on/off key light. If the light is on, you have successfully programmed your remote. If the light blinks four times and turned off, you have entered a code number that is not in the code lists or have missed a step in the code procedure. Try the previous step again.
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
I need a code for RCA tv
I can help you with your URC-3021 Universal Remote Control.
The codes for RCA TVs are: 0047, 1047, 1147, 1247, 1347, 1447, & 1547.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Jun 06, 2010 | One For All URC-3021 Remote Control
My controldosent work with the codes
I can help you with your URC-3220 Universal Remote Control issues.
The URC-3220 codes for Emerson TV's are: 0154, 0236, 0463, 0180, 0282, 0178, 0019, 0179, 0177, 0185, & 0623.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
If these don't help, try the One For All URC-3220 Code Search.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Reassign Key
Oct 02, 2009 | RCA RCU300 Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA RCR311B Remote Control
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
I have an rca universal remote and a magnavox tv. cant find the instructions on how to program
try this, press and hold the tv button on your remote about 3 sec. light should stay on, then enter code, if it's a good entry light should shut off, then try to turn tv off. make sure your tv is on before trying this. If tv does shut off then you're done if not try other codes magnavox codes0062 0004 0009 0183 1133 0226 0288 0456 0008 0068 0075 0141
Feb 20, 2009 | RCA Universal Remote Control
Cant find code
lock in our manuel for manuel code entry those universal remote dont alway got the code manuel code entry take some time it should work cheers
Jan 17, 2008 | GE JASRM24912 Remote Control
Programming Problem
Try the Philips codes as well...
Jun 09, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
