Question about Audio Technica AT-PL120 Turntable
Missing Non-slip Mat
I received an AT-PL120 turntabel unit as a birthday gift. Whe I unpacked it every thing was there but the Non-slip mat.
Can you send me one?
If there is a charge, can I use a credit card?
William R. Green
1296 County Road 202
Gainesville  TX  76240-8205
USA
vallevistafarm@ntin.net
  • 94 Answers
Just search on ebay there about 4-5 pounds it would be alot easier as paypal is usable on ebay.
Posted on Oct 18, 2007
My turntable does not have a slip mat
then contact the manufacturer thru either their phone number or website ,we can not help you with this .
Jan 24, 2016 | Audio Players & Recorders
How to solve an inverse of matrices
You must be in the RUN screen.
Press Menu
Press 1:Run
Press OPTN
Under tab F2:Mat you get the MAT tab.
To invert a non-singular matrix A (a matrix with non-zero determinant) you, on the command line type in
Mat A then press the [x^-1] key. The [x^-1] is the shifted function of the right parenthesis.
Mar 25, 2014 | Casio FX-9750GPlus Calculator
Ddr universe 3 dance mat will not turn on with xbox 360
if that is the case, you need to return the dance mat and let the store test it.
Jan 04, 2014 | Konami Dance Dance Revolution Universe 3...
I just bought my first yoga mat and went to use it for the first time and I am slipping everywhere. Is there something I can do to prevent slipping?
Essentially, you need to accelerate the aging process. You may want to put your mat in the laundry machine. Continue to use your mat and soon enough it will become more worn - causing you to slide around much less.
Jul 31, 2012 | Exercise & Fitness
Do I really need a yoga mat for doing yoga?
Yoga mats are used so that your hands and feet do not slipout from under you while you are practicing the various poses. In moreenergetic forms of yoga, this non-slip surface is especially important, assweat can build up on hands and feet. This could cause serious injury, or atbest an uncomfortable bruise. Yoga mats also offer a degree of padding forknees and elbows if you are practicing poses on a hard floor.
Jul 09, 2012 | Exercise & Fitness
I am unable to solve determinant of matrix.
Here is enough to get you started and a little more.
Read the post ant consult your calculator manual.
How to calculate the determinant of a (square, non-singular) matrix is described in part B
A. Define a matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). example. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
B Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Example : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
C. Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
D. Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [*] (MAT) [ALPHA] B [EXE]
Part E Invert a (square, non singular) matrix that was already defined.
Press [OPTN] [F2:Mat] to open a screen similar to the one in capture above
Press [F1:Mat] to have identifier Mat displayed.
Enter the name of the matrix by pressing [ALPHA] A, for example.
Press [SHIFT] [ ) ] activate the (x^-1) key.
This is what you might see (with parentheses and without).
Press [EXE] button to calculate the inverse.
Apr 08, 2011 | Casio FX-9860G Graphic Calculator
How do i solve systems of linear equations with matrix? I set up the matrix A and B but how do i do A ^-1 B?
Suppose square matrix A and compatible matrix B, and that Mat A is non-singular.
  1. Press [MENU] key and go to RUN screen.
  2. Press [F2:MAT] to access the matrix tabs
  3. Press F1:Mat]. The Mat identifier is entered on the command line.
  4. Press [ALPHA] key then A
  5. Command line now shows Mat A.
  6. Press [SHIFT][ )] to activate [X^-1]
  7. Press [*] multiplication key then [ALPHA] and B.
  8. Command line now shows Mat A^-1 * Mat B.
  9. Press [EXE] to display the result.
Apr 06, 2011 | Casio FX-9750GPlus Calculator
My LG front load washer bounces and is really loud during the spin cycle. I've tried balancing it in all directions and recently put a thick rubber, non-slip mat underneath but now it's moved the mat!
make sure all the shipping bolts are taken off and if they are you probably arent totally level but it sounds like the shipping bolts are still on there and that wont let the dryer level like its supposed to the bolts are usually on the bottom and usually have a tag saying remove after shipping
Feb 24, 2010 | Washing Machines
Audio Technica AT-PL120 Turntable Logo
75 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Morne Olivier
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
