Question about Westinghouse 26" LCD Flat-Panel HDTV
Tcl tv led color fades in and out - Westinghouse 26" LCD Flat-Panel HDTV
I have tcl led m. no 24d20 only displays tcl logo and then no responce
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again. Also try bringing up the menu, and see if there's an option "factory default", and try that.
Feb 04, 2016 | Televison & Video
How do i connect my Acer Aspire one D270 with TCL LED TV 40. When i connect my laptop through HDMI port screen blinks but nothing shows on LED TV .LED TV just says not supported.My laptop Graphic is I
Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
Dec 10, 2014 | Acer Aspire One D270-1865
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
My tcl 32ins led tv color started to show white . What is the problem color ic or the screen.two tecnishon say so
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 16, 2014 | Televison & Video
Tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Jan 25, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
TCL 21M62s TV showing standby led light on but not power on this tv
The red standby is on because the tV is not turned on. Once you turn the power ON the red led will go out and possibly another color will come on.
Oct 29, 2013 | Protron PLTV-32 Television
Tcl lcd tv lcd screen trouble
TEST the CRT, color gun, demodulator, see the block diagram attached.
Jul 20, 2013 | Televison & Video
Westinghouse 26" LCD Flat-Panel HDTV Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
