Question about Bosch Ovens
Replace ceramic top bosch hb7052c - Bosch Ovens
Where can I find an equivalent thermal sensor?
This will work for you. WB21X5301. When you get the part, snipp the plug of the old one if the new one doesn't fit, it has ceramic wire nuts to connect the old plug to the new sensor re-install and your golden.
Jan 18, 2016 | Bosch Ovens
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
I have an electric range with a ceramic top. How do I clean it? There is bubbles on the ceramic too, is this from overheating? How do I get those off?
the main killer of glass cooktops is sugar.it fuses with the top and you cannot get it off. the best way is a razor knife scrape it at a 30 deg. angle. there are some cleaners made for smooth tops as well.good luck!
ERIC
Jan 23, 2010 | Ovens
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
I just shatter the top of my stove ,glass ceramic, can it be repaird.. it's a glass cake cover fell handle first and 3 of the burners have cracks running through them ..do i hve to replace it or can it be...
Unfortunately no your ceramic glass top cannot be repaired and will have to be replaced. as for the burners as long at the metal heating part of it isn`t damaged and its just the outer white coloured insulation that is cracked or chipped this is okay and still operate normally.hope this helps
Thanks
Oct 12, 2009 | Maytag Ovens
I cracked my stove's ceramic glass cook-top
replace the glass. it may be expensive but usually fairly easy
Jan 04, 2009 | Ovens
Replacing the ceramic top
I remove the whole hinge and top from the back put the old hinge on the new top then move the burner to the new top put the whole hinge on the back of the oven.. hope is is a little help
Jun 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
20 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
