Master air cooler md 9000c - Heating & Cooling
I need a new water Pan for my adobe Master Cool Model EC630G Master Cool Cooler????? Where can I get one, and how much for cost?
You can find the parts here:
http://www.indoorcomfortsupply.com/Mastercool%20Plus%20Parts.html
I am pretty sure your going to have to order the wet section U pan for your model. (Item 19) / $249.95
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Mastercool 67680 Evaporative Cooler Air...
Can you use Handy Master Fire Fan Heater Md#HMF 13 inside?
yes,i have the same one.just make sure it is not pointing at anything an keep it in the center of the room.do not use it as a substitue for your normal hous heating system.
Oct 07, 2010 | Master Heaters Master B115DT 115,000BTU...
Need a power supply for the cooler master CAC-T05-UW
I've used Cooler Master, Rosewill, Antec without fail. Warranty 2+yrs, power efficiencies >75%.
Jan 07, 2010 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
HOT AIR BLOWING INSIDE THE HOUSE
I know there are not that many sites--very few--that cover the informational guidance on the maintenance and technical difficulties of evaporative coolers, and so I feel compelled to share with you this very good, but rare, handyman site that does:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
As you'll see, the link above has a section dedicated to evaporative coolers.
As to your specific problem of your cooler's blowing hot air, yes, the humidity is listed as one of six (6) possible causes of this cooler problem. To find out whether the other five causes are applicable to your situation, here is the direct link to the diagnostic article on hot-blowing coolers:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Does_Not_Blow_Cool_Air.htm
You should be able to review this article, and, one by one, determine what causes listed therein are not affecting your cooler in order to ultimately end up with one remaining listed cause that is the likeliest cause of your cooler's failure to blow cool air into your house.
This should help.
Brad
Jul 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water Leaking from pump
How COOL is this. At first I thought this was some crazy graphics card cooler that I've never heard of!
Well here is the manual anyway.
http://www.air-n-water.com/manuals/MMB12-4Manual.pdf
And here is a Parts Catalog from a company in Arizona I found at random. This one takes a little longer to load just give it time.
http://www.dialmfg.com/Technical%20Assistance/TECHINICAL%20PDF%20DOCUMENTS/2008%20Cooler%20Parts%20Catalog-all.pdf
Jun 10, 2009 | Cooler Master Coolermaster CoolViva Video...
No low speed on my mobile master cooler module no mmb12c
Could be as simple as the switch, could be as complex as a pole burned out on the motor. If you reverse the connections on the speed selector switch and you end up with low speed and no high speed then you know it's just an inexpensive switch.
May 30, 2009 | Cfm 2000 Swamp Air Cooler MMB10 MasterCool...
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
