Question about Polaroid PoGo Instant Digital Camera Z230E
Polariod Z230E printer won't print.
It makes a quiet whirring noise, quieter than the normal print noise, and no paper comes out, even when it is loaded.
My polariod pogo, seems to be jammed but their is no paper inside and when there is it doesn't want to print and says check printer and it makes a weird noise. HELP!!
A weird noise suggests either the mechanism is broken or there really is a jam.
When there's no paper inside, how sure can you be that there isn't even a tiny piece of paper, smaller than your smallest fingernail, in any part of the mechanism? One way to remove a tiny scrap would be flush it with a vacuum cleaner set to blow...
May 19, 2016 | Office Equipment & Supplies
Brother HL 1440 won't print
Try first unplugging power, and removing toner
check inside for foreign objects or fragments of paper
Open all doors and close them back , and plug back power.
Sep 04, 2008 | Brother HL 1440 Laser Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
My printer Canon PIXMA E510 prints very slow.
See if it has a quiet mode for using it late at night. It prints slower, but much quieter.
It also depends on what you are printing. PDF files are the worst, because they are in fact a huge image.
Treat yourself to an MG7120 like I have. Fast and quiet, plus wifi enabled. I print from my iPhone.
Jan 11, 2014 | Office Equipment & Supplies
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Noise when beginning to print or copy
Mine always makes noise too, I don't know why. But I know that it's a lot noisier when paper quality is set for draft, so you might want to check that.
If you just go into the printer properties, under the tab that's something like Paper/Quality. There will be a drop-down list where you can choose the quality of your print out, i.e. Best, Normal, Draft or FastDraft. If it's set for Draft, you might want to change it to Normal. Draft uses less ink, but it also doesn't come out quite as clear, and is very loud.
Mar 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
Polaroid PoGo Instant Digital Camera Z230E Logo
22 people viewed this question
Top Polaroid Computers & Internet Experts
Larry Maranto
micky dee
Tom Chichester
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
