Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Getting no water in the filter it is being by pass, when I took out filter there was no water in it put a new in and still the same, it is a kenmore elite 795.77543600
  • 318 Answers
Its most likely a frozen water tank. try and clean the coils by the compressor and then make sure the temps for refr are set around 38. it might need to be warmed up inside the refr section. you can tell if its too cold by the vege's if lettuce, carrots and celery are crispy, then you might need to clean the coils.
Posted on Dec 31, 2013
Sea Breeze
  • 4655 Answers
SOURCE: No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Posted on Nov 24, 2009
SOURCE: I need help replacing a Kenmore Elite Water Filter - 46- 9010
insert it so it is vertical and then rotate one quarter turn to the right so it is now horizontal nad the line matches the grill on the front of the fridge.
Posted on Jan 27, 2010
  • 12 Answers
SOURCE: kenmore refrigerator water filter replaced now
did the filter get put in backwards?
Posted on Jan 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: i bought a new water filter for our kenmore elite
Check the oring seal for damage. If it is not in place - the filter will not fit properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
imufo2
  • 3773 Answers
SOURCE: kenmore elite 596 with water
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 07, 2011
Kenmore Coldspot refrigerator Model #57282791 no water from dispenser
When was the last time you changed the fridge water filter. Sounds like its blocked if no water is coming out of the hose at the bottom front. Also depending on the fridge design two other culprits are possible.the electric switch that is pressed that cativates the water valve to open and let water pass and the second the water valve itself. I would lean toward the water valve at the back of the fridge, as you said it was getting worse over time u til it just stopped.
Oct 02, 2017 | Kenmore Refrigerators
I am getting hardly any water through the door...I took the filter out, but this does not help. Also we only get one to two ice cubes whenever it decides to make ice.
Check the water inlet at the valve behind the refrigerator to make sure you are getting good water pressure. If not good pressure the problem will be with your supply. If the filter is in the unit and you have purged all the air from the system problem will be the water valve.
Feb 28, 2010 | Kenmore Refrigerators
No water from dispenser
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
Dec 21, 2009 | Kenmore 56722 / 56724 / 56726 / 56729
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Whirlpool - problem with ice maker
that blue part is your water filter. if you will buy a new one and replace it you should be fine. Peyton
Feb 18, 2009 | Whirlpool Refrigerators
No water
hey we got this one.the buzz is the water valve solinoid energizing when you push the paddle for chilled water,so power is passing thru switches in your refer and getting to the water valve.[good]then we need the water to do its thing,and even though you said you changed the filter[i would'nt have yet],because there was work going on for the water lines.there may have been tons of minerals broken loose.the water valve also has screens to catch minerals and stop them from entering water valve.some water valves are not cleanable.if yours not im sorry replce the valve.if it is you will see the way as you inspect..................but heres a very important matter.before you replace valve,filter or anything that has been blocked by a mineral blast,flush your lines in a bucket.other wise you just recontaimanate with whats still in the lines.i know it took a lot of words to say a little.and it didnt come out just as i was thinking it but i hope that helps.God bless ,tom
Jan 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge icemaker doesn't work after move
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 11, 2008 | GE Profile PSI23NCR Side by Side...
Ge Profile bottom freezer, french door refrig, water filter
Just replace GE's filter with a standard inline filter that hooks to 1/4" water line tubing. Sounds like their filter has no flow rate either...
Here's a popular one:
http://cgi.ebay.com/AICRO-GAC-IN-LINE-FILTER-2-X-10-X-1-4-FNPT-JG-FIT-/390180520853?pt=LH_DefaultDomain_0&var=&hash=item99ab36a9be#ht_500wt_721
Jun 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
