Question about Thermador C302U Electric Double Oven
What is code F 24? - Thermador C302U Electric Double Oven
    Champion:
  • Thermador Expert
  • 320 Answers
Short in panel. replace touch pad and relay board.
Posted on Feb 03, 2015
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire 24" Built-in Single Electric...
Thermador over has f 24 code
fan/ air flow issue. search here for another post I did explaining the correction.
May 20, 2014 | Thermador SC272T Electric Double Oven
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Got error code f-10 how do i fix this
Hello, the f-10 error code is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Thanks
Jun 11, 2010 | Frigidaire 24" Built-In Single Gas Wall...
What does the F 5 error message displayed on Frigidaire - 24" Built-in Single Electric Wall Oven FEB 5 56cbs mean?
Hello there:
Here is what the code means and what needs to be dne to resolve this problem
F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control)0dd70e1.jpgShould be something like this
Jun 05, 2010 | Frigidaire 24" Built-in Single Electric...
F7 CODE
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
F9 Program w/ door circuit Check wiring
Mar 21, 2010 | GE Built-In 24" Double Electric Wall Oven
Maytag gas oven has an F3 code and beeping. Model # CGR3740ADW.
Hi. This code is the result of a shorted, or open(circuit) oven temperature sensor device. You will need to Check the sensor harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
Dec 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Apr 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Thermador C302U Electric Double Oven Logo
75 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
