Question about Cuisinart EM-100CP Espresso Maker Cleaning Pins
Espresso machine sprays espresso
Brand new machine for Christmas. It constantly sprayed espresso out the back of the brew head, so I returned it and got another. Same thing. I've tried different grinds from course to fine, different tamp pressures, different levels of espresso in the filter with the same results (always fresh Starbucks espresso beans). One thing I did notice is that sometimes it drips okay if I brew the espresso before frothing milk, but if I froth milk first and then brew espresso, it always sprays out back. But this only helps sometimes, and that is backwards anyways, as the espresso has cooled down when it has to wait for the milk to froth. I noticed the filter only has one small hole for the drip. My older Starbucks Barista filter has many holes in the filter and I never had this problem. Any ideas that I can try before I take this one back as well and spend more money on a different brand?
  • 8,073 Answers
Read the manual.
Posted on Dec 30, 2013
Testimonial: "I've read the manual ... several times. Seems you think there might be something in there that I've missed though. BTW .. not sure how I put this under Cleaning Pins, but I can't figure out how to change my category to just Cuisinart EM100 Espresso machine :("
2 Suggested Answers
  • 15 Answers
SOURCE: Half of the time, espresso leaks (or sprays) out . . .
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Posted on Dec 08, 2011
Why is there water spraying from coffee head and surrounding area
Grind is too fine and the portafilter chokes when water hits the coffee; or the seal in the brewing head is shot.
Jul 31, 2014 | Gaggia Baby Coffee Makers & Espresso...
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Only brewing half of decanter
Remove and clean the spray head above the filter basket. If it still under fills, there could be a problem with the dispense solenoid valve.
Apr 22, 2014 | Bunn Dual SH DBC
Bunn cwtf20-3 makes weak coffee
When you pull the basket out after its finished brewing what does the surface of the coffee look like? Are there 6 or so clearly defined dimples in the surface where the water pours from the spray head? Is the powder uniformly wet? If the answer is no to either of these, remove and clean the spray head. Use a descaling tablet or powder to soak the spray head and then use a small tool to clear the holes. Be careful not to make the holes bigger though.
Aug 08, 2013 | Bunn CWTF20-3 Automatic Coffee Brewer -...
Weak Coffee
First think to check is the spray head which pours the water onto the powder. remove the spray head, clean it and soak it in descaler.
reassemble and do a brew. When finished check the surface of the coffee has 6 dimples where the water has poured onto it and that the coffee is uniformly wet. If no dimples or dry spots, get replacement spray heads.
Jul 27, 2013 | Bunn VPS Coffee Maker
Will not brew
Make sure the coffee maker is full of water. Keep filling it till water comes out of spray head.. Should take two full pots plus 3/4 of another one. Wait for water to stop coming out of spray head. Now the unit should be ready to brew after it heats up.
Mar 29, 2013 | Bunn VPR Coffee Maker
We have vlpf series coffee is not coming thru
take basket off, and unscrew sprayhead, clean out holes and rinse spray head and screw it back on, then try to pour some water thru, if it comes thru, then brew some coffee
Mar 11, 2013 | Coffee Makers & Espresso Machines
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
Coffee stopped coming out of nozzle
The problem with your machine is the connection where the brew unit connects to the dispensing head is broken. This is why the machine is leaking into the dump box. I wish it was an easy fix, but it is not.
You will have to get the machine serviced.
If you would like to have your espresso machine serviced please visit the service page of our website:
http://cerinicoffee.com/Espresso_machine_service.asp
Cerini Coffee Services
Authorized Saeco Service Center
Nov 14, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Airlock in new machine
I have a similar problem, I think. I get water through the steam thing, but not through the brew head. Not sure what to do either.
Oct 07, 2008 | Gaggia Classic Espresso Machine
Cuisinart EM-100CP Espresso Maker Cleaning Pins Logo
51 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
