Question about Frigidaire Freezers
LFFH21F7HWB E8 CODE AND -10 FLASHING - Frigidaire Freezers
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Feb 05, 2015 | Frigidaire Freezers
How can remplace control boad at frigidaire freezer model LFFH21F7HWB
That model does not have a control board. What problem are you having? The unit does not cool?
Nov 06, 2012 | Maytag Freezers
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Error code E8
Check wiring to evaporatorsensor. If correct, replace sensor. That will require a professional's attention.
Jul 29, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
E8 code on display
E8 code on kenmore freezer
Apr 30, 2010 | Frigidaire Freezers
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
Frost free fridge/freezer
that is an error code call manuf. for solution
Dec 06, 2007 | Freezers
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Freezers Logo
26 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
