Question about Dryers
How to put a samsung dryer back together dv4006jw2/xac
3 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
Posted on Jun 08, 2009
odiebugs
  • 949 Answers
SOURCE: SAMSUNG MODEL DV218AEB/XAC LEAKING WATER
Dryers don't use water, washing machines do, so it's probably the washer.
If the dryer is drying, then it's not moisture.
Check the house drain for the washer, watch it drain and make sure it's not backing up, check the drain hose.
Posted on Apr 03, 2013
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
Apr 03, 2013 | Samsung DV218AE Electric Dryers
No heat model dv665jw/xac
Element or thermal trip on element, you will need to test them with a meter, as to which one, But if thermal trip gone, why, could be element on way out.
Mar 18, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
How to dismantle
Where is the element heater of Samsung DV203AES/XAC?
Nov 29, 2011 | Samsung DV218AEW Electric Dryer
Not heating
Is there power to your heating element. It is probably not working.
Feb 27, 2011 | Samsung DV328AE Electric Dryer
I have a barely 1 year old samsung dryer (DV203AES XAC). It used to work fine. Up until about a month ago. The problem we have now is in "Normal" mode (where the machine detects how damp or...
I have the same problem. When the timer approaches 0:00, it adds one hour. Try turning off the power (breaker) for a while and turning it back on. It works for me.
Jan 29, 2011 | Dryers
Samsung Model # DV203AES/XAC Doesn't dry any more. 2 years old
circuit board replace and maybe wiring harness.75/25=100dollars parts
Oct 15, 2010 | Samsung Dryers
Hi, I have problems with SAMSUNG Dryer Model # DV665JW/XAC. It does not dry clothes at all. Could u please help!!! cheers, lucina
you probably have a broken wire in the heating element. located on the back of machine, top right corner, behind panel.
remove the two screws
Sep 01, 2010 | Samsung Dryers
Need to read owners manual for samsung wf218an washer
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
Aug 30, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
