Question about Vehicle Parts & Accessories
Where can I replace the battery for this J.starter, #JS450CP
Can the fuses in the relay box be the problem if its not the battery or starter
It could be the the starter cable. From the battery to the starter. Jump the starter from the small wire to the big wire at the starter. If it turns fast, look to the ignition(small) wire to the starter. if it acts the same, replace the battery to starter wire/cable. Corrosion is the problem.
Oct 08, 2016 | 2003 Buick Rendezvous
I have a 2001 pontiac montana and am trying to figure out how to change the starter.
STARTER REPLACEMENT (ENGINE ELECTRICAL) Document ID# 688149 Starter Replacement
Removal Procedure
Important: This vehicle uses the PG260 F1 starter motor. The starter motor is serviced only as a complete unit.
  1. Disconnect the battery ground (negative) cable from the battery. Refer to Battery Negative Cable Disconnection and Connection.
  2. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Remove the starter motor BAT terminal nut and electrical leads.
  4. Remove the starter motor S terminal nut and electrical lead.
  5. Remove the torque converter cover. Refer to Torque Converter Cover Replacement in Automatic Transaxle - 4T65-E.
  6. Remove the starter motor bolts.
  7. Remove the starter motor.
Installation Procedure
  1. Install the starter motor.
  2. Notice: Refer to Fastener Notice in Cautions and Notices.
  3. Install the starter motor bolts.Tighten:
    Tighten the starter motor bolts to 47 [n-m] (35 lb ft).
  4. Install the torque converter cover. Refer to Torque Converter Cover Replacement in Automatic Transaxle - 4T65-E.
  5. Install the starter motor S terminal electrical lead and nut. Tighten:
    Tighten the starter motor solenoid S terminal nut to 3 [n-m] (27 lb in).
  6. Install the starter motor BAT terminal electrical leads and nut. Tighten:
    Tighten the starter motor solenoid BAT terminal nut to 10 [n-m] (89 lb in).
  7. Lower the vehicle.
  8. Install the battery ground (negative) cable to the battery. Refer to Battery Negative Cable Disconnection and Connection.
Aug 05, 2016 | 2001 Pontiac Montana
Starter location
Its in engine compartment under hood.
On the lower side.
First test the starter before directly replacing it.
It can be faulty starter or there is loose connection from battery to starter. The starter assembly gets power from battery. Check voltages at starter wires and see if you are getting 12 volts or not. If not then its no power issue due to low battery volt or no connection between battery to starter.
To solve these problem, I suggest you to refer these direct help links:-----
Click the link below: ------
How to test starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test cars starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
These will help.
Thanks.
Dec 10, 2012 | 1998 Chevrolet Blazer
Starter wont engage after replacing dead battery
Check power to starter motor solenoid, solenoid operation and starter motor voltage during cranking. If the starter motor is receiving power from the solenoid, but isn't cranking, then replace the starter motor.
Also check the condition of battery terminals, wiring and connections. Also check the earth wire from the body to the engine.
Nov 12, 2012 | Cars & Trucks
My 1997 Chevy Lumina will not turn on. I thought it was the starter since it started having difficulties turning on. The security light on the dash is permanently on. So i replaced the starter and tested...
REPLACE BATTERY CABLES THE POSITIVE BATTERY CABLE COULD BE SHORTING TO GROUND.REPLACE STARTER SOLENOID IF NOT BEEN REPLACED.BESURE TO PLACE BACK FLEXIBLE CONDUIT THAT GOES AROUND POSITIVE BATTERY KEEP FROM SHORTING TO GROUND. LAST TIME I SEEN BATTERY CABLES OVER HEAT WAS EITHER STARTER AND SOLENOID SHORTING OUT OR VERY LOOSE BATTERY CABLES CONNECTIONS. REPLACE BATTERY CABLES IF THEY ARE MELTED HAVE STARTER CHECKED OUT YOU COULD HAVE FAULTY STARTER STILL.
Sep 06, 2011 | 1997 Chevrolet Lumina
How do i replace a starter on a 110 yamoto 4 wheeler?
starter should be in the front of the motor if not track down the starter remove the negitive cable on the battery and two bolts on the starter remove the starter wire and pull the starter out replace starter and replace neg battery cabel...
Jul 20, 2011 | Garden
I have A 91 EF SI....with a 93 b18b1 starter ticks but will not start....replaced starter and had it rechecked and its fine....battery has good charge.....and there is power going to starter...pgm-fi main...
It sounds like your battery needs to be replaced. When you battery has a dead cell, or is weak, the starter solenoid may click, but the starter will not turn over. Since you replaced the starter, and you have power going to the starter, I am sure you have a bad battery.
Mar 12, 2011 | Honda Civic Cars & Trucks
I have a gmc 1998 turbo diesel that cranks but wont turnover or try to..i have replaced the supply pump as well as the inline pump..what can i do to get my truck started ..thank you ?
TURN OFF RADIO FIRST TO KEEP FROM LOCKING IT OUT WHEN YOU DISCONNECT NEGATIVE BATTERY CABLE. SOUND LIKE WEAK BATTERY OR STARTER MAKE SURE BATTERY CABLES CLEAN AND TIGHT.IF BATTERY GOOD REPLACE BATTERY CABLES.CHECK STARTER MAKE SURE STARTER SOLENOID AND STARTER OKAY.YOU CAN HAVE THEM TESTED AT AUTO PARTS STORE OR USE A REMOTE SWITCH.REMOVE STARTER FROM VECHICLE USE JUMPER CABLES.HOOK NEGATIVE GROUND CABLE TO BATTERY NEGATIVE THEN GROUND STARTER BODY WITH NEGATIVE BATTERY JUMPER CABLES HOOK POSITIVE JUMPER CABLE TO BATTERY POSITIVE AND STARTER POSITIVE TERMINAL.THEN HOOK REMOTE SWITCH TO STARTER STARTER SWITCH AND OTHER REMOTE WIRE TO STARTER POSITIVE TERMINAL.PRESS REMOTE STARTER WILL SPIN IF GOOD.MAKE SURE INJECTION PUMP STATIC AND DYNAMIC IS TIMING CORRECT BEFORE STARTING TRUCK.
Dec 07, 2010 | 1998 GMC Sierra
Starting Problem
Probably a bad starter as well. A good battery can make a marginal starter work, but over time the battery will be weakened by the drain of the starter or the starter will get worse.
Remove the starter and take it to your local parts store for testing and replacement. Bring your battery along as the bad starter might have toasted it.
Also a bad battery can wear out a starter quickly.
We had issues like this with our pickup truck a few years back. Replaced the battery, worked okay for a while, then the replaced the starter, worked okay for a while, then the battery was bad. Eventually replaced both and haven't had any issues since.
So when replacing one it is a good idea to check the other.
Jan 12, 2010 | 2000 Dodge Caravan
Need to replace the starter on the 97 mitsubishi Diamante, how hard is it to remove and replace ?
To replace the starter you need to;
) Note if you have an anti-thief system and now to reset it if the battery is disconnected.
) Note the radio station selections if they are not saved if the battery is disconnected.
Now
) Disconnected the GROUND connector on the battery.
) Disconnect the electrical cable on the battery.
) Remove the 2 bolts holding the starter on. Remove the harder one to reach first.
) Pull the old starter out.
) Insert the new starter.
) Replace the bolt. Insert the easier bolt first.
) Tighten the bolts.
) Replace the electrical cable.
) Reconnect the GROUND connector on the battery.
) Reset any radio, clock or anti-thief systems.
) Return old starter for a core charge refund.
May 25, 2009 | 1997 Mitsubishi Diamante
Vehicle Parts & Accessories Logo
79 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
