Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Where is oven gas shut off valve on pgb918sem4ss
LP gas bottles are full but no gas coming through to hobs or oven. Is there a valve between the bottles and the oven?
Yes, in the USA there should be s shut off valve on the top of the tank, and also a regulator somewhere before the gas gets to the oven.
Apr 28, 2018 | Kitchen Ranges
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Oven and grill do not ignite appears to be no gas coming through either
check with multi meter ur oven safety gas valve and more than likely ur igniter switch? although the oven safety gas valve dont commonly go out it may somehow have shut off the gas as it has an on/off button usually red in color that can be tripped? check to see if its in off position
Mar 06, 2015 | New World G70m Gas Double Oven
No gas to the burner or oven
Hello deodatramdin - If both the range and oven are not working, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. While the unit is turn off, confirm that the shut off valve on the gas pressure regulator is in the "ON" position (typically located on the back left-hand side of the range). This valve shuts the gas off to the oven. Once you have verified, turn the range back on. If it proves to be ineffective, then the range could possibly be experiencing an issue with the EOC, wiring failure or faulty power supply. Contact a certified technician to move forward accurately and to assist with the repairs.
Jan 30, 2013 | Frigidaire FGB24S5A Gas Single Oven
I can't find the pilot light shut off valve on my Magic Chef oven. Where is the gas shut off valve? It is 20 years old, uni burners with self cleaning oven. 314-837-1073
Good chance there is no shut off for the pilot by its self. Of course one should have been installed at the back where the line comes into the house. If you are smelling gas please turn off your gas until you find the problem.
Aug 16, 2010 | Ovens
Replaced bad thermostat on Magic Chef model 9112xpb. Ignitor now glows orange but oven still won't start. Does gas valve on bottom of oven need to point up or sideways to start?
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
May 16, 2010 | Magic Chef Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Oven working no gas to range
Check to make sure that you are getting gas to the unit itself. If you are getting gas to the unit from the shut off valve. Then your problem would be the gas valve will need to be replaced. This is the only thing that would not let the gas flow to the unit itsef
Jun 03, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gas range..surface buners light...oven does not.
Usually the gas valve is behind the stove. pull it out from the wall and look behind it. Code requires the shut off valve to be in the same room as the stove so if there is no shutoff valve it would be a good idea to call your gas supplier and have them take a look at the problem. They will look at it and advise you for free.
Mar 31, 2009 | Ovens
Brand new gas range
i would look into the valve/regulater at which you connected the gas line, off to the side or somewhere on the regulater itself there should be a shut off for the oven control, simply flick to open positon and you should start right up. it would shut off gas to oven but allow burners to light.
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
15 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
