Question about Breville CT75XL 4-Slice Toaster
Toasts on one side - Breville CT75XL 4-Slice Toaster
Why does my toaster ony toast one side of the bread
Because the nichrome wire on one side of the toast has broken.
Its time to get a new toaster.
Mar 17, 2015 | Baking
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Toaster not toasting on one side
No doubt the element is out on that side . You may be better off just replacing it unless it has some sentimental value to it . Chances are the element won't be found since it is that old.
Jan 27, 2013 | Kitchen Appliances - Others
My toaster only toasts on one side of the bread...can I replace the toasting elements? It's a Kitchen Aid brand.
The kitchen aid brand is usually a good one,
i prefer you too replace the toasting elements because in my brand i faced the same problem and i replaced the toasting element . it worked wonders for me
Dec 29, 2009 | Kitchen Appliances - Others
Left-hand section only toasts on one side
The heating resistor on the left side has shorted with the case. Since you don't know very much on electrical equipment (to fix it you would have to open it, remove the shorted piece of wire, reattach all and insulate them properly) and the price of a new item is low, just buy a new one and discard this one. You shouldn't use it again, under no circumstances - if you're unlucky it can kill you.
Oct 03, 2009 | Breville Kitchen Appliances - Others
Toaster only toasts on one side
Please ensure that the "Bagel" function is not selected (LED is not lit up). The Bagel function will toast one side of the bread while only warming the other side.
Mar 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Infrared toast
Is the element glowing on the other side? Is the unit being used correctly ie, the correct toast setting versus 'top brown'?
Mar 10, 2008 | Microwave Ovens
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Breville CT75XL 4-Slice Toaster Logo
51 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
