Control Module WMA34
I have got a new Control Module for Hotpoint WMA34 but having problems with the wiring, has anyone got a diagram please. I have forgotten where the wires go.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
If my memory serves me well, the plugs/wires will only fit the correct spots on the module, and I believe there is a "jumper" on the original module, make sure you remove and install in the new module..Good Luck
RMK
Retired GE Technican
Posted on May 21, 2009
Hotpoint WMA34 diagram
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 31, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi again, answered on you other posting ;-0)
John C
Aug 31, 2011 | Washing Machines
2003 denali air ride control problem. Compressor was bench tested and runs when 12 volts is applied. Tested pressure switch on air filter (3 wire) and no continutiy between any of the three terminals. I am...
What color wire's ? There is a relay which is controlled by the ESC module (computer ) Electronic suspension control module . The relay supply's B+ power to the compressor . Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. Year , make , model and engine size. Under system click on suspension then under subsystem suspension controls will pop up on it's own . Click the search button then the blue link's . System can set DTC'S - diagnostic trouble code's . Has hight sensors , control module ,relay etc.....
Sep 27, 2017 | 2003 GMC Yukon Denali
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
Hotpoint door not locking
i think the problem from what you saying come from { a water level swith} because it contol also the door from opening when the water is still in the drum so it may need to change from the begining >
thanks
Jul 09, 2009 | Hotpoint WMA33 Front Load Washer
Aj nide instruchyn HOTPOINT WMA34
Hi.
Log onto -www.hotpoint.co.uk
Then click After sales service,then download user manual.
You can then view this on screen, or print it off.
Please leave feedback.
Nov 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Jun 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Door lock light flashing
WASHDOCTOR
Rank:guru_s.gif Guru
Rating: 87%, 146 votes
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Apr 29, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA34 Where to find the motor to change the brushes
DON'T FORGET TO UNPLUG THE POWER FIRST!
Remove the lid and the motor is sat to one side on top of the drum.
Oct 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
