Question about 3M Dynatel 965dsp Subscriber Loop Analyzer 965dsp-b 965 Dsp
The software is corrupt on my DSP 965; I need the code to reset the software
How to I repair corrupt software?
My dynatel 965dsp hang
Hola, haz encontrado alguna solucion para esto?
Jan 22, 2014 | 3M Dynatel 965dsp Subscriber Loop Analyzer...
Cant open quickbooks , message pops up error code 8000ffff
If your problem did not solve till now, i would suggest you third party tool which will repair your corrupt QuickBooks file and save your data in working condition.
http://www.recoverfilesdata.com/quickbooks-file-recovery.html
Free to Try Version is Available
Aug 10, 2012 | Intuit QuickBooks Pro 2008: Windows
Hi i have a nokia 5130 but i forgot my security code wats to be done..tell me plz. i got the master code but wen am entering it,its saying wrong code. thanks zaina
Hi. I too not believe that master code is really working.The best way is to contact nearest mobile repairing shop.They can generate the current code without missing any data or the can reset the code by using some repairing tools like MXkey/ Turbo Flasher (For generating code).I thought that you have known the default code 12345.This is the procedure when keypad lock could not remember.Thanks for visiting fixya.Good luck
Sep 13, 2011 | Nokia 5130 Cellular Phone
Security code
if you need security code or forget security code you need to reset your phone. you can try resetting your phone through codes. its the safe way to reset your phone. because when you reset your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you reset through codes. thats y i prefer this method to reset my phone. i got the codes from this site Classicunlocking.com to reset my phone. try it
Aug 18, 2011 | Cell Phones
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
My behringer ub2442fx pro has the numbers 88 flashing red in the display and a clicking sound every time they flash. any idea what the problem is?
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Dec 20, 2009 | Behringer Music
My phone is code corrupt what doi do
You need to take your phone to a repairer and it will be flashed or formatted with its software thereby, resetting and putting the phone back to its factory default state.
Take care
Dec 08, 2009 | Motorola Mobility RAZR V3x Cellular Phone
HTR-5240 Will not play audio when switching to DSP
Most likely your DSP board is bad, usually a pretty costly repair and sometimes the board is hard to find in stock.
DSP--Digital Signal Processor
Dec 01, 2007 | Yamaha HTR-5240 Receiver
3M Dynatel 965dsp Subscriber Loop Analyzer 965dsp-b 965 Dsp Logo
168 people viewed this question
Top 3M Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a 3M Measuring Tool and Sensor Expert? Answer questions, earn points and help others
