Question about HP LaserJet 6p Printer
A 3 inch wide band prints on sheet from top to bottom
    Champion:
  • HP Expert
  • 312 Answers
Could be a worn out fuser or bad cartridge. Try a replacement cartridge first.
Posted on Jan 31, 2015
3 Suggested Answers
  • 990 Answers
SOURCE: dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Posted on May 06, 2009
KingDWS
  • 1606 Answers
SOURCE: Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
Posted on Dec 30, 2009
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
On the right hand side of a print there is a band about 1 cm wide
For the last half inch or so of the print the printhead swaps the direction of print - if you listen you can hear the change, and, if you open the cover and wedge something into one of the now exposed holes on the left side, to push down the switch (this will fool the printer into thinking that the lid is shut and enable you to print) thenyou'll be able to watch it as well.
It must be something to do with the end of paper sensor triggering it, but why it has the effect of creating this banding I've no idea. By all accounts it's a common problem with the i9950. Some folks report sticking a post-it note to the top back corner with an inch or so showing fools the sensor. I've not had any luck with this but it's worth a try.
Mar 27, 2010 | Canon BubbleJet i9950 InkJet Photo Printer
Dec 30, 2009 | HP LaserJet 1100 Printer
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Dark band the length of the right side of the printed page
Apr 07, 2009 | HP LaserJet 1020 Printer
Unprinted stripes on sheets
could be the drum causing the issue or the scanner assembly.
Jan 16, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
HP LaserJet 6p Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
