I have a Dell 9300 and bought a new battery and power cord a few weeks ago. Now it won't charge or stay charged even a few minutes. It seems like the cord connection is not staying in the port.
  • esther66 May 19, 2009
    This makes complete sense..... charges in some positions and not others. Thank you!@!!!!!!!!!
  • 13,433 Answers
If its a brand new charger and cord, so the problem can't be on the cords or the battery then its most likely the plug on the motherboard thats faulty, broken or loose. re soldering or properly soldering it in place should solve the problem, or replacing it incase the old one is broken.
now this should solve the problem, definitely if you move the plug around and you notice that it charges on some positions and not on others, then thats confirmed as your problem.
if replaceing or fixing that doesn't solve the problem then the issue is on the motherboard, could be the power circuits, or other related components on the motherboard, Now I do have laptop motherboards here next to me, it is going to be extremely difficult to replace and or find the faulty components on the motherboard and 90% of the time can't be done at home, you will need to seek the help of a professional or contact dell for repairs, if your on warranty it might be a free repair, but I can't guarantee that.
Posted on May 19, 2009
  • Ekse May 19, 2009
    You can't reply to me anymore, so if you want you can email me your response at nikoht@gmail.com
    Did you replace the charger and its only the plug that you move to get the laptop to charge? your not moving the cord? I had the same problem few years ago I suspected that the plug on the motherboar was loose but it actually wasting, the problem was that the other wire that came from the charger had gotten loose inside the charger and didn't touch - so no charge coming.
    But if you replaced your whole charger so that can't be your problem and it must be the loose plug.
    let me know, thanks, at email nikoht@gmail.com
    Niko / Fixya - Ekse
I purchased a Maxwest Orbit 5400 a week ago. Even with the phone turned off, the phone charged very slowly. I mentioned it to the vendor, and he recommended that I change batteries. I did so, but the...
Could be your charger (cord). Borrow another of the same type and try it. Make sure you aren't plugged into a power strip or surge protector.
May 05, 2017 | Cell Phones
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
My power cord does not stay charging while plugged in. Normally I hear the beeping as it conects and disconnects, up to 20 times a minute. Do I have a bad power cord? Is the best result just to purcharse a...
If it keeps connecting and disconnecting, it could be either the power adapter or the motherboard, but chances are it's the power adapter (and that's the cheaper solution too). You can usually get a new power adapter for $15 or $20, and that should take care of your problem.
Jun 01, 2010 | Gateway NV5215u Notebook
Inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 22, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Stopped working a few weeks ago - bought and installed new battery seemed to be working OK - now after about a week, it goes for about 15 minutes then stops...
It may need a longer charging period to bring the battery up to full charge. If you have a voltmeter, measure the battery voltage while it is being charged--it should read several volts above the rated battery voltage. If nearly equal, the charge unit may need repair or replacement. Good luck!
Jan 04, 2010 | iRobot 4150 Roomba Vacuum
We have a Dell latitude d600 and the old battery had gone bad some time ago, would charge, but lasted maybe 10 minutes. We bought a new OEM Dell battery for it, and put it on charge all night. The charge...
Sounds like you should try a regular Dell factory refurbished battery. Or if not that, try a battery that you knows works for sure. Then try charging it up, if it doesn't charge up then you know its a situation with the motherboard.
Dec 29, 2009 | Dell Latitude D600 Notebook
Insprion 600m Reddish Tint when on Battery Power
hi there,
you are probably not getting enough power source from the battery or the battery is getting old and not charging fully or holding its charge ,is my guess good luck..try a new battery...
Jan 22, 2009 | Dell Inspiron 600M Notebook
Dell Latitude 500 - Battery vs Power Supply Problem
As far as which adapter to use, either should work fine. The 90 watt will run cooler. I have seen the 65 watt go up in smoke when being used on a continuous basis.
As to the battery not charging, unfortunately, it sounds like you may have a problem with the internal power supply. The orange light is showing that the battery is discharged. If this light doesn't turn green after the laptop has been plugged in for a couple of hours, you are not getting the battery charged. Power the laptop down, remove the battery. Check the contacts on both the battery and laptop battery connector for any foreign material or "Gunk" and for any bent or broken contacts.
Hope this helps!
R-
Nov 03, 2007 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
