Aeg lavamat 70720 code c3 - Washing Machines
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
taran_2005
  • 10515 Answers
SOURCE: What means error code
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 28, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
  • 174 Answers
SOURCE: aeg oko lavamat 72600 update, ce error code
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
Hi my AEG OKO-LAVAMAT 88830 is about 10n years old. Today I was cleaning my machine. I filled the machine up with water on the rinse cycle then turned it to pump. I did this a few times as I have had a...
According to my list for AEG Lavamat washers, 'C3' stands for 3 possible causes 1 'safety flood device operated' (I suspect it means that it has sensed some water in the bottom tray. Not an easy job to do but I would check for a leak underneath), 2 'pump fault' and 3 'module fault'. Sorry I can not be of more help ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | AEG Lavamat 88840 Front Load Washer
Stop washing and showing c3
c3 means you may have a leak . some models have a float switch in the base sensing water leaks.
Jun 14, 2010 | AEG Lavamat 72640 Front Load Washer
My AEG lavamat 74620 doesnt fill up with water
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
May 06, 2009 | AEG Lavamat 72640 Front Load Washer
Error code C3
LOOK IN YOUR MANUAL...IT SHOULD HAVE A SOLUTION TO THIS CODE..JUST FOLLOW INSTRUCTIONS...BEST OF LUCK..
Jan 11, 2009 | AEG Lavamat Lavalogic 1600 Front Load...
AEG Lavamat 88840 display C3
Good Luck!
Jan 02, 2009 | AEG Lavamat 88840 Front Load Washer
Error c3 lavamat 86800
Hello there,
Dec 27, 2008 | AEG L86800 Front Load Washer
Aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
May 08, 2008 | AEG L86800 Front Load Washer
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
