Question about Welding Tools
Sealey supermig 180/1 wont feed the wire when trigger is press help
It never gave any trouble before
  • brian boyle
    brian boyle Jan 04, 2014
    the wheels dont turn is there a fuse for the motor to drive the wire
  • 10,137 Answers
Can you hear the motor? If you can, tighten the tension on the wheel. If the motor is not runnung, check the trigger switch to see if it's working. A wire in the handle may have broken.
Posted on Jan 16, 2014
luis_david
  • 407 Answers
SOURCE: lincoln 140 hd turns on
Hi:
Try by-passing the trigger switch by disconecting the trigger cable cord (not the gun) and using a wire bridge the connector at the machine, if the motor turns, then your problem is the gun switch, that's an easy replacement, if not then you have a problem with the motor itself or the pc board and you will need to sent it in to a pro for repair.
Posted on Aug 11, 2011
SOURCE: runs but gun dosenot opreate, it is a clarke 130en
The only things I can think of are:
  • The tension on the coil of welding wire is too tight and needs slackening off.
  • The feed rollers need cleaning and the tension adjusting.
If none of these solutions solve your problem then I can not help you any further.
Posted on Dec 04, 2008
luxur4
  • 92 Answers
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
  • 7 Answers
SOURCE: wire feed motor wont run
Do the wire drive wheels turn?
if not then trouble shoot wire feed system for defect.
Posted on Mar 21, 2009
SOURCE: NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
Posted on Apr 10, 2009
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
Spoolmate 100 wont feed
Check for binding int he inner sleeve first, then increase tension as long as feed motor spins. If feed motor does not spin check wiring to make sure it is connected correctly.
Sep 18, 2012 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
Hello, I have a Hobart 180 and the wire feeder motor won't run. I replaced the wire feed motor and it still won't run. any ideas?
Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
Jun 27, 2011 | Hobart Welding Tools
Relay clicks, but wire feed motor wont operate
check for power to drive motor,if power is there when you pull gun trigger then motor is bad.if no power look for bad wire connections then relay.
May 09, 2009 | Welding Tools
Wire feed motor wont run
Mar 17, 2009 | Welding Tools
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
237 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
