Question about Archos ARCDisk 20GB 4200rpm 480Mbps USB 2.0 USB 2.0 External (500455FT) Hard Drive
Remove drive from Arcdisk 20
I need to know how to remove the Hitachi Travelstar drive from an Arcdisk 20GB. I want to try and find another case/shell/enclosure to move the data to another drive. Power plug on drive is non-working.
  • Archos Master
  • 10,263 Answers
If the power plug on the drive doesn't work, putting it into an external case is pointless.
Posted on Jan 12, 2014
Hello, quick question: I have a totally broken IBM laptop, and I've removed the hard drive, which is a 40GB Hitachi Travelstar 5400RPM ATA/IDE: Exact model#: HTS541040G9AT00 I'd like to copy the...
Yes! There is such an adapter. Look here for IDE/SATA to USB: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770
Obviously, you don't have to buy this product or buy from Tiger Direct; this is just an example of the type of product you're looking for.
If you're comfortable working inside your desktop, then you should check out this product which is much cheaper: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329310&CatId=3770
Good luck and thanks for using FixYa.
Mar 16, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
My drive is fine but my laptop died. I am looking for a compatible laptop that I can plug my drive into to recover the data.
An easier way of doing this is purchasing a 2.5" USB external casing (it's a cheap option too). You can then connect it to another computer via USB and backup your data. From what I can see it's an IDE drive rather than SATA, so make sure you get an IDE compatible casing, if you chose to do this.
Here is a good example of one:
http://www.amazon.com/Drive-Aluminum-External-Enclosure-Capacity/dp/B000FNBYKW
Jan 23, 2010 | Hitachi TravelStar 4K120 HTS421212H9AT00...
No power to hitachi drive even with "toaster-like" help
You may want to remove the drive and place it into a PC with the correct interface SATA or IDE.
If the PC can read it then the issue is with the enclosure and not the drive.
Sep 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Ilooked up the spec on my computer from dell (that
u need a SATA (serial ATA) drive, buy a SATA drive and its compatible with most of the computers today.
u can read about SATA drive by clicking this link i am giving:
http://en.wikipedia.org/wiki/Serial_ATA
plz do not forget to vote and click yes if i solved your problem,thank u! :)
Sep 05, 2009 | Hitachi TravelStar DK23FB (08K1427) 40 GB...
Hitachi Travelstar HTS541010G9SA00
No the drive is not customized at all. It is a standard SATA Data and Power connector. However, if it was already mounted in a laptop chances are the laptop manufacturer may have put an adapter on the connector end to allow for tight right angle insertion into the laptop chassis which isn't possible with the stock connectors without leaving the drive loose in it's slot.
If this is the case grabbing the connector and pulling straight away from the drive should pop it loose and reveal the stock SATA connectors under it.
If you're having troubles removing this peice, comment back with the make and model# of the laptop it came out of and I'll see if I can pull a diagram for you.
Chris
Jun 04, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
HTS424020M9AT00 hard drive will not boot up.
If it is clacking you will need to replace your hard drive.
Nov 15, 2008 | Hitachi Laptop 20GB (13G1489)...
HITACHI 20GB C4K60
It should work without any jumper settings.
If it fails to work then you can use a jumper to go for lower capacity option which i really feel you shoul never got to cause it will just work
Mar 24, 2008 | Hitachi Travelstar C4K60 (08K1532) 20 GB...
Backing up the Hard Drive
I take it your hard drive is IDE. Most enclosures only support 3,5" inch harddrives with either SATA or IDE interfaces. A notebook's HDD can have the IDE interface but it's way smaller than the standard.
There is an option however, it isn't necessarily an enclosure. You can look for the A.C. Ryan uDrive. It's a USB device which allows you to connect harddisks or optical drives from three different interfaces without the hassle of building in the drive in an enclosure.
If this is what you need, check this page:
[A.C. Ryan uDrive]
You'll need to connect your harddrive to the 2,5 inch drive connector on the device.
I hope this is what you were looking for.
Let me know if this solved your problem.
Greetings,
DarkNeogen
Jan 24, 2008 | IBM TravelStar 40GNX 40 GB Hard Drive
Computers & Internet Logo
Top Archos Computers & Internet Experts
fordexpert
Computer Links
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
