Question about Winter Sports
Snowmobile troubleshooting snow mobile misfires and stalls at idle
    Problem Solver:
  • 12 Answers
Dirty carburetor or fuel. Siphon out the fuel; refill with new fuel (must be fresh-- not more than a few weeks old). Start it and let it run for a while. If this doesn't work, remove the carburetor and clean all the tiny jets. Have fun.
Posted on Jan 10, 2014
Engine will not idle, stalls when throttle released
Make sure your drive clutch is disengaging all the way.
Mar 07, 2014 | Arctic Cat 2004 T660 Turbo Touring
Polaris troubleshoot
If I was a betting man, you should do a compression Test on your Engine. What you are going to find is the PTO Cylinder has a lower compression than the Cylinder on the Right. Doing a Top End Repair on your Sled will only take 4 hours to do correctly. You can do RINGS ONLY but you may want to replace the Piston if the SKIRT has marred the Cylinder Walls to ensure a longer life. It is also recommended that you make sure your Oil Injectors are not clogged and functioning correctly.
Feb 11, 2014 | Polaris 2004 EDGE Touring 340
Ski doo engine troubleshooting
What is your Issue?
What are you troubleshooting?
What is it doing?
Misfire?
Lack of Power?
Engine Light?
Have you Checked your Compression?
Do you have a Dirty Carburator?
We need much more information..
Jan 02, 2014 | Ski-Doo 2010 MX Z TNT 600
Snow mobile misfires and stalls at idle.
You have a Blockage of your IDLE Jets. It is Starving for Fuel, it could also have a problem with the Size of the Jets for your Altitude.
Dec 30, 2013 | Winter Sports
Stumble off idle
Stumble off idle,you have a misfire at idle the ignition system is of concern this will include plug wires sparkplugs cap and rotor,
Mar 03, 2012 | 1995 Dodge Dakota
My 93 olds cutlass ciera keeps misfiring and stalling, i have change the spark plugs, fuel filter, o2 sensor, maf sensor, and still stalls and misfires any ideas?
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Engine Misfire codes for car?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Engine Misfire codes?
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
This will help.
Thanks.
Feb 14, 2012 | 1993 Oldsmobile Cutlass Ciera
1990 Chevrolet Lumina Base 6 Cyl 3.1L (88,000 miles) June 3, New spark Plugs installed. (Original Spark Plug wires remain) July 15, Power Brake Booster Replaced. Shop said battery was disconnected...
recommend getting a scan of the OBD II connector for trouble codes, then get back to us. Autozone and Advance have free scanning service. The trouble codes will help us diagnose the specific misfire. With the codes, I can provide you some recommended troubleshooting or repair steps.
Oct 02, 2010 | 1990 Chevrolet Lumina APV
I was recent given an arctic cat ''jag'' snow mobile and don't know ghow to find out what year it wass manufactured.
Look for a tag on the side of the snowmobile tunnel that says what year it was made. You will typically have to add 1 year to the year that the tag says.
Feb 06, 2010 | Interactive Toy Concepts Crossfire Arctic...
Cant get my snowmobile started
you need to remove the old gas and replace
drain gas line if you can get to the carbs use starting fluid
( remove spark plugs and observe also clean with gas and wire brush
also while you have the plug out put the metal side of the spark plug (where you woud turn with a wrench) and turn over with ignition switch
to make sure u are getting a spark
good luck and happy snow mobileing
Jan 06, 2009 | Sport & Outdoor - Others
Winter Sports Logo
324 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
