Question about Motorola Mobility DROID 4
Notifications only ring once then go to screen
Is there a way to make them ring for a longer time??
    Master:
  • 519 Answers
In Settings--Read Owners Manual--If you don't have one , can be downloaded from web.
Posted on Mar 16, 2014
How do I set my samsung S111phone to repeat the notification of a text until I answer it?
Kindly follow the steps listed below to do so:
  1. Go to Apps through Home screen.
  2. Tap Messaging.
  3. Tap the Menu key.
  4. On pop up menu select Settings.
  5. Scroll to Notification settings section then tap Message alert repetition.
  6. Here you can see three options available on pop up menu. They are:
    • Once: Choose this option if you want your phone ring the tone just once when receiving an incoming messages.
    • Every 2 minutes: Choose this option if you want your phone ring the tone every 2 minutes until you open the message.
    • every 10 minutes: Choose this option if you want your phone ring the tone every 10 minutes until you open the message.
  7. Tap the required message alert repetition option you wish to use. When the dot indicator next to the option shows green means the option is selected.
  8. Tap Home button to return to the standby mode.
By adjusting message alert repetition just once or more than once, now your phone will notify you when receiving new message and repeating the tone according to the settings you've just done. So, what's the option you use on your phone?
Sep 24, 2014 | Samsung Cell Phones
My nokia e73 stopped alerting me when I get a text. the light will flash when I get a text but there is no sound. My cell rings when people call, I made sure that in settings>tones my message alert is...
for it to make noise try deleting all of ur mesages from ur inbox and out box. For the blinking to blink longer gp to ctrl panel-settings-general-personalization-notification lights-notification light-blink for-select no limit
Jun 25, 2011 | Nokia E73 Mode Cell Phone
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
Instructions
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life ' eHow.com http://www.ehow.com/how_8087565_optimize-blackberry-bolds-battery-life.html#ixzz1HLj9WRhr
Mar 22, 2011 | RIM BlackBerry Bold 9000 Smartphone
Calender alarm only rings once
in alaram setting keep alaram all the day so you can get the alaram daily
Apr 09, 2010 | Palm Treo 755p Smartphone
Can't set my blackberry curve to ring and vibrate at same time
To silence your device
In the profile list, perform one of the following actions:
• To receive LED notification only, click Quiet.
• To receive vibrate notification only, click Vibrate.
• To turn off all notification, including notification profile exceptions and LED notification, click Off.
Hope this helps!
- CBR2009
Aug 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
Call forwarding only rings once
You will have to have the admin lengthen the voicemail answer time, i would add another 15-20 seconds.....but this will make all calls ring your phone longer before going to vociemail
Mar 09, 2009 | Avaya 5400 Series 5410 Phone
Motorazr V3 Status indicator no longers displays envelope for voice messages
Why am I receiving a memory full notification? space.gif space.gif answer.gif Memory full warning notifications are shown once the SMS memory reaches 80% full, which is 80 out of 100 SMS.
The notifications show up every time on receiving a new message. On reaching 100%, "Memory full notification" message is shown and no new messages will be received until we make space for incoming messages by deleting some from the inbox.
Memory full warning notices are shown only if "Auto Erase Inbox" is set to Off in Messaging settings (Menu -> Settings -> Messaging).
If set to On, then these notices are not shown. By default this is set to Off.
Oct 22, 2008 | Motorola Mobility RAZR V3
I`m getting achievments on my gamescore card ie the points... but im no longer getting getting notification of my achievments on screen while i`m playing.....help me please............
Make sure you still have your 360 set to receive notifications. At the dashboard with no game loaded or loading. Press the middle button shaped like a globe with the X in the middle on your controller once, scroll down with D-pad to to Personal Settings and click A, scroll to notifications and press A Under the "Set notifications options" heading make sure all three options are checked to reactivate them.
Aug 27, 2008 | Video Game Consoles & Games
Eliminate the "Inbox Full" and new text message notifications
well the answer to the first question is ya you can turn the annoying notifications off. All you have to do is go to menu-settings-audio-vibe & ring detail. then u scroll down to messaging and change it to silent.(your phone may not me vibe & ring detail its watever setting you have it on (ex. loud ,vibrate,vibe then ring) and this is followed by the word detail
Sep 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility DROID 4 Logo
46 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
