Question about LG Televison & Video
Lg dp132 check region code
How to change to Region 0?
  • Jason Smith
    Jason Smith Sep 10, 2016
    I actually solved this fairly quickly by reading lots of posts and trying different things.
    I burned an ISO which I booted in the drive. This gave me an option to choose a new region and save it. So suspect it was 0.
    After that a Region 1 disc played perfectly.
    I also used AnyDVD to make a region 1 drive appear as region 0. Then I copied the DVD with CloneCD and it changes the copy region.
  • Elmisa Blues
    Elmisa Blues Nov 06, 2016
    No me aparece ninguna pantalla, realizando los pasos que mencionas, acaso hay otra manera?
    New Friend:
1.Switch on the DVD player without any Disc inside
2.The screen should display 'no disc'
3.Eject to open the DVD tray
4.While the tray is open, press the 'STOP' button then hold the 'ENTER' button for 5 seconds
5. A new screen will appear (Regional Management Test Code) which will allow you to change the region code using the up and down arrow keys on the remote control.
6. Change the code to '0' and press the PAUSE key to exit
Posted on Jan 24, 2016
  • 19 more comments
  • Bill Broers
    Bill Broers Jan 31, 2016
    Thank you Larry! This worked beautifully for me with my new LG DP132 (2016/01). Following this procedure I was able to change my region code to "0".
  • shakeel Feb 08, 2016
    as u said it was worled and helpful to me, thank you very much, ofter purchasing i suffered a lot i have region 3 dvds and it was not play first but ofter changing to region code all dvds are playing.
  • Astrid Leigh
    Astrid Leigh Apr 07, 2016
    It worked, thanks!!
  • Stuart Oreilly
    Stuart Oreilly Jul 04, 2016
    Does not work for mine??
  • I cant get even the new screen. Is there another solution?
  • Julie Noon
    Julie Noon Sep 25, 2016
    Worked great. I first tried to hold stop button and enter key together when that didn't work I realised you press stop then just hold the enter key only for 5 seconds. Thank you
  • Anonymous Dec 26, 2016
    Just bought two of these for the kids because they they could be made multi region however this operation doesn't seem to work, build date says sept 2016 could the software have been changed to stop this working? Anyone had any luck doing it a different way, remote has no numbers so that's not an option.
  • Kimberley laine
    Kimberley laine Dec 28, 2016
    Omg... after searching everywhere, this worked!!! Yay thank you!!
  • Boeken.A A
    Boeken.A A Jan 04, 2017
    The solution worked now my DP132 is region free thanks a lot
  • Zsolt Bede
    Zsolt Bede Mar 07, 2017
    For me doesn't work! Any help, please!?
  • Chrisy Tyson
    Chrisy Tyson Mar 29, 2017
    Didn't work for me either. Need help.
  • Chrisy Tyson
    Chrisy Tyson Mar 31, 2017
    If anyone find another solution, please post it, this one doesn't work and I don't know why it works for some but not all when it's the same dvd player - LG DP132.
  • MrNefrego
    MrNefrego May 10, 2017
    didn't work
  • Phil Jul 12, 2017
    It worked perfectly for me, thank you!
  • Phil Jul 12, 2017
    Worked perfectly for me, thank you!
  • Lee Cushman
    Lee Cushman Oct 20, 2017
    nope not for me
  • jeanchris TOPHE
    jeanchris TOPHE Oct 22, 2017
    No does not work
  • Kaushik Bhattacharya
    Kaushik Bhattacharya Nov 22, 2017
    Worked like a charm for me!
    Just received my set today and used this fix to change it from Region 5 (India) as shipped, to Region 0 and was able to play my US (Region 1) and UK (Region 2) DVD without any problem!
    Perhaps all those of you reporting failure are from North America, because I remember reading somewhere that this fix doesn't work on sets factory set to Region 1?
    But for those in India at least, you can safely buy and then make the set Region free!
  • tom simunsen
    tom simunsen Apr 01, 2018
    I have an LG DVD player DP132 and it worked easily. =)
  • Evie Fieseler
    Evie Fieseler May 11, 2018
    This fix worked perfectly and easily! Thanks! Follow what Larry Lirex says just above. You do not need number buttons on your remote.
  • paul cadman
    paul cadman Aug 12, 2018
    sorry does not work got from Argos august 2018 no hacks will work ?
    New Friend:
Not helpful at all. LG dp132 remote has no numbers to press.
Posted on Aug 25, 2015
    New Friend:
This does not work any suggestions. I have lg do312 dvd player
Posted on Sep 10, 2016
SOURCE: Multi Region for LG DV398H
for 'all' LG dvd players to break coding follow these steps.
it worked for me, i was told it works for all LGs...
step 1- POWER ON "NO DISC" appears on screen;
step 2- press PAUSE, 3, 1, 4, 1, 5, 9;
step 3- "CODE_ _" appears on screen;
step 4- 0, PAUSE, then POWER OFF!!!
that's it, good luck guys! hope it works
Posted on May 22, 2009
jaffa012001
  • 376 Answers
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Posted on Oct 19, 2008
SOURCE: LG Blu-Ray BD-370 unlock codes
http://www.multi-region.net/lg_5931
Posted on May 01, 2009
SOURCE: How to setup Region code free for DVD LG DV 487
Power on the dvd player without any disc on it.
Press the PAUSE button and then the following numbers
3 1 4 1 5 9
Then you will be asked which region you want to set up.
0 = All regions. 1 = Region 1. 2 = Region 2 etc.
Then press pause again.
Then power off the dvd, and then turn it on.
I just did it with mine that was setup to only reagion 4 and couldn't watch region 1 dvds.. I set it up to = 0 (all).
Hope it helps.
Posted on Oct 04, 2009
Ragoney
  • 158 Answers
SOURCE: I RECENTLY BOUGHT LG BD 550 ..THE PROBLEM IS I
it depends on what region your player is, most likely you need to unlock your region code(if there is an available unlock for your player) if you want to play that disk. but it simply means your dvd and your player is not on the same region
Posted on Mar 23, 2011
Tip
LG DV582H region free code
Here are the steps to make your LG DV582H DVD region free.
1) Power on (with no disc)
2) Wait for msg "No disc"
3) Open tray
4) Push three times number 0 (i.e.: 0 0 0)
5) A blue screen appears with the code region factory set, and the option to set the new region code
6) Press 0 (zero)
7) Press Pause (A msg say that you have to press de new code and them press pause to confirm....so, is to easy)
8) Close tray
9) Turn off
Works 100% for my LG DV582H region 4, now its region free!!
Good Luck
on Jan 03, 2011 | Audio Players & Recorders
I have a LG dp132 maid in 12-2016 how do I change region code
If you wish to get more details visit the site linked here. Region code hack procedure to many popular brand devices are given. http://electronicshelponline.blohspot.com/ http://homenol.blogspot.com/
Feb 25, 2017 | LG Televison & Video
Need a regional unlock code for LG DP132 please ...
Power ON with NO disc inside:
Press PAUSE on the remote-control
Press 3,1,4,1,5,9 in sequence using the remote-control
Press 0 on the remote to select Region Free
Press PAUSE again to save
Power OFF then Power ON.
Done.
Oct 15, 2016 | LG Electronics - DP132 Multi-Format DVD...
Region free code for LG BH7520
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
Jun 10, 2012 | LG Televison & Video
Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Aug 03, 2010 | LG Televison & Video
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
Lg dvdcombo region codes
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Nov 28, 2008 | LG 32LG40 32 in. LCD HDTV
I own an LG (LH-W750TA) DVD player that is set for DVD region 4. I am after an unlocking code to allow me to view DVDs from region 1 NTSC.
Open tray
Press PAUSE
Enter 0 0 0 0 0
Region change screen should appear.
Enter region 1 - 6 or 0 for multi-region.
Press PAUSE
Apr 23, 2008 | Televison & Video
Televison & Video Logo
17,141 people viewed this question
Steve Allison
Steve Allison
