Question about D-Link DWM-156 3.75G HSUPA USB Adaptor
Verifying event not connected to internet and always in status "verifying event" when trying to connect to internet
beeveez
  • 167 Answers
SOURCE: dl-524 status blinking, cant connect to internet
- Updating the firmware of your router will do to fix the issue.
Posted on Mar 15, 2009
  • 45 Answers
SOURCE: cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be 192.168.1.1, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Posted on Mar 19, 2009
kakee
  • 1269 Answers
SOURCE: new dir 625 with DSL-cat5 connection and NO internet on status.
If it keeps on trying to connect to PPPoE, try not to use PPPoE setting. Use Automatic Configuration or DHCP connection type.
Posted on Jun 10, 2009
SOURCE: D-link dir-615 cannot connect to internt
it could be a problem with your internet connectivity. check with the isp.
Posted on Jul 27, 2009
govinda123
  • 2260 Answers
SOURCE: d-link 615 wireless router having problems
You will need to check the wireless settings of the router. If possible then upgrade the firmware of the router. try changing the wireless channel of the router. Is there any computer connected to the router? If not then connect the computer to the router and open the set up page of the router.
Click here for step by step instructions
Posted on Apr 05, 2010
I try log on it says check your connection but I have full bars
->Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection.
->Verify that the Internet light on your wireless router is solid or blinking green. if all light is on then it is connected otherwise it will give the connection error.
->You can also check router status under Maintenance after login the router.And you will see the IP address .If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 15, 2012 | Computers & Internet
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
How do I set this router up with AT&T Internet?
Hi Friend,
Make sure that you have connected all the wires/cables to their respective ports/places. Please follow the steps:
1.Open web browser and type 192.168.1.1 and hit enter.
2.Enter admin as username and password.
3.Select the proper region.
For cable modem:
* For most cable modem users, you should be able to connect to the Internet without any
configuration. If your ISP has provided you with a host name, enter it in the optional Host
Name field.
* If your ISP requires a registered MAC Address, click on the Clone MAC Address button.
Click Apply and OK to save the setting.
* Go to Status tab, Internet connection section to verify if you get the valid IP address
information.
For DSL:
* Select PPPoE from the drop-down menu.
* Enter your username and password provided by your ISP.
Click Apply and OK to save the setting. Go to Status tab, Internet connection section to verify if you get the valid IP address information.
4.Click Wirless (to configure wireless settings).
SSID: Any name as per your choice.
Operating Mode: Infrastructure
Authentication: Open System
Channel #: 6
WEP: Enabled and type any ten digit number as your password. You can use this password whenever you try to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Airlink AR430W Wireless Router
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
Apr 25, 2010 | Computers & Internet
Hello, I just installed a new router, and it all
verify your internet modem it connected to the WAN port on your WRT160N, login to the WRT160N and go to the "status" tab and see what your internet status is. You should see a page similar to this:
moz-screenshot.pnghttp://i117.photobucket.com/albums/o64/arcticpaws/linksys.png
Verify your router has an Internet IP address. If it does not, then you haven't finished configuring your router. If it does have an IP address, then turn off your firewall and see if you can get connected that way.
Oct 03, 2009 | Linksys WRT160N Wireless Router
Cannot detect network connection
Instead of running the CD, try to configure the router manually. First, make sure that you have verified internet connectivity between your PC and your modem. Once verified, connect your modem to the internet port of your router and then your PC to any of the ports (1, 2, 3, or 4) at the back of your router. Turn ON your modem, router and PC.
On your PC go to Start>Run> then type "cmd" and hit the Enter key.
On the black screen type ipconfig/all and hit the Enter key.
Check the IP address of your Local Area Connection.
If it is 192.168.1.xxx, then you are good to go.
Check the connectivity between your PC and the router. On the black screen type ping 192.168.1.1 and hit the Enter key.
If you're getting replies, minimize the window and open a browser.
Type http://192.168.1.1 and hit the Enter key.
Once prompted with a username and password type admin (admin is the default password).
Once you're on the Web interface of the router, enter your internet connection type and then save the settings.
Once done, click on the Status tab and then check the internet IP address.
If there's an internet IP address, try to open a new window and see if you can access the internet.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Kt600 8237
-Check your cables and power status first. -verify your internet connection via router or modem -Scan for viruses -Fix wndows Errors -check your network properties and status
Sep 28, 2007 | Soyo KT600 Dragon Plus Motherboard
D-Link DWM-156 3.75G HSUPA USB Adaptor Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
